A/C blower
Old Jul 4, 2020 | 06:23 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default A/C blower
I am sure anybody that has an early C 4 has noticed that the A/C fan is kind of anemic.
has anybody come up with a blower that puts out more air?
i replaced mine with a new Dorman blower because the bearings or brushes were squealing.
i expected go get a bigger blast of air with a new motor, But all i cured was the squealing noise.
it’s 112 today and i just need more air.
Old Jul 4, 2020 | 06:38 PM
LiveWire1's Avatar
LiveWire1
I have an 85, and I noticed the same thing. I removed the blower and using a nylon brush, I made sure that the AC unit was free of leaves and crap. (There was lots!) I also looked at the high speed blower relay, located below the motor and found that it was not working at all. It only needed a cleaning of the contacts in the connector plug and it worked once more. So, now I have more air, but you're right... Pretty anemic on the whole.
Old Jul 4, 2020 | 06:54 PM
krackenvette's Avatar
krackenvette
Not sure if a newer blower can help, but, is there debris in there? My 93 Keeps me very cold, all I run is recirculate button 99% of the time..
Old Jul 4, 2020 | 07:03 PM
coupeguy2001
Default Blower
I have the automatic temp control.
it seems like it us not closing the valve that goes to your feet.
i may just have to give it vacuum all the time so it’s closed or just wire it shut
Old Jul 4, 2020 | 08:05 PM
RWDsmoke's Avatar
RWDsmoke
My 86 uses the same blower as my 02 s-10 had. But in the s-10 I always ran it on low because it would blow your hat off on high speed. I replaced the a/c evaporator, which was partially plugged with debris and removed the restrictions in the center vents with a Dremel. It made a huge difference. Also, check the blower control module if you have climate control. Sometimes they don't put out full voltage and need to be replaced.
Old Jul 5, 2020 | 03:32 AM
GregMartin's Avatar
GregMartin
This was kind of touched on above but are all your vacuum controlled air “flaps/doors” working correctly? The if the door to the windscreen demister is open then just about nothing comes out the centre vents.
Old Jul 5, 2020 | 10:12 PM
coupeguy2001
Default Blower
I used a piece of metal to hold the defroster completely shut
the dremel idea sounds like a good one.
in what universe Did those engineers decide too much cold air was a bad idea?
To A/C blower
