Steering Rack leaking... Room for improvement?
Old Jul 7, 2020 | 07:06 AM
prez1967's Avatar
prez1967
Default Steering Rack leaking... Room for improvement?
Have a leaky steering rack. Likely tie rods but "while im in there"... is there a rack upgrade to sharpen up the steering? Any bushings I can swap out for better steering feel?
Any suggestions would be appreciated.
Car is a 1994 ZR1.
Old Jul 7, 2020 | 08:34 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
My '88 has the "quick steering" option (2 turns lock-to-lock) while the '89 has the std unit (2.25) turns and I definitely "feel" the difference between the two cars.
Not sure if your '94 has the option; you might check say Rock Auto to see what options they offer for your car if any.
Old Jul 7, 2020 | 09:12 AM
Kevova's Avatar
Kevova
Rack is mounted with rubber bushings. There are urathane bushings available. The flex coupling canbe checked for wear. IDK if there is a u joint style replacement. The previously suggested Z51 quick ratio rack.
To Steering Rack leaking... Room for improvement?
