93 rear speed sensor help
Old Jul 8, 2020 | 04:15 PM
radar502's Avatar
radar502
Default 93 rear speed sensor help
Did I do this right ,removed the ear speed sensors cleaned ( were dirty ) sprayed brake cleaner in the hole cleaned the wheel that the speed senor feeds off of is clean looks good . Volt mender set on volts probe on one side and one on the other nothing switched the leads still nothing ,had to turn the hub by hand but was fast enough to make Volts . I did the fronts the same got 3-4 volts .. I seen on you/tube the guy has the motor running ,not happening on this one waiting on new OPTI spark .. Both bad ??? Any surjections .. Thanks ..
Old Jul 8, 2020 | 06:56 PM
IBVETN2's Avatar
IBVETN2
Do you have a FSM? If so check the resistance ohms of each sensor against the shop manual. Not sure what the reading should be on a 93, but they should all be close to the same.
Old Jul 8, 2020 | 06:59 PM
Kevova's Avatar
Kevova
You may not be able to spin rear tires to get a reading. Sensor needs to be seated in knuckle, sensor won't pickup if there too much air gap. I would recheck it when engine starts.
Old Jul 8, 2020 | 07:12 PM
IBVETN2's Avatar
IBVETN2
I can spin the wheels on my 86 fast enough by hand to get a reading for my K/M abs tester .
You can ohm test the sensor at the connector, while it is out of the car.
Old Jul 8, 2020 | 08:25 PM
radar502's Avatar
radar502
I cleaned them and reinstalled before I spun the hub . I did the fronts the same and got -3-4 Volts ?? Rears might be different . My new OPTI will be in tomorrow I'll start it and spin the rears and see what happens .... I can't bereave both are bad ????? Thanks
Old Jul 8, 2020 | 08:26 PM
radar502's Avatar
radar502
I'll check the OHMs out .. Thanks ..
To 93 rear speed sensor help
