C4 electrical problems
Old Jul 19, 2020 | 11:47 AM
We Bad's Avatar
We Bad
2nd Gear
Default C4 electrical problems
My 93 was in a frontal collision. I repaired the damage but my interior lights won'tcome on when I open the doors, fog lights won't work and my right side head light motor won't work. All fuses are good. I replaced motor, there is no power going to motor from harness. Any help out there?
Old Jul 20, 2020 | 05:23 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default Power
The accident may have shorted a wire that goes to a fusible link.
dont have a wiring diagram for your year, but that’s my guess
Old Jul 20, 2020 | 05:32 PM
We Bad's Avatar
We Bad
2nd Gear
Thanks, is a fuse link noticable when bad?
Old Jul 21, 2020 | 09:59 AM
jazfe's Avatar
jazfe
For the front of the car I would check all of the ground wires. Ensure they are all clean and tight.
The interior lights could be the door switch is stuck because of the hit the car took during the collision.
Old Jul 21, 2020 | 10:47 PM
hcbph's Avatar
hcbph
Most times I've had them go bad, the big ones - no. Some will shrivel the wire around the ballast while other times they won't. Thing I've done before is with the battery disconnected, put a small straight pin through the insulation on either side of the ballast and then check from one pin to the other with an ohm meter. If it's continuous, it's still good.
To C4 electrical problems
