Is YOUR tach accurate?
Old Nov 28, 2002 | 05:06 PM
ELEVENS's Avatar
ELEVENS
Default Is YOUR tach accurate (VOTE HERE)
Lets see who's got a decent tach, and who doesn't. You know, misery loves company!
For this poll, please consider both static and dynamic (rapidly accelerating) readings.
[Modified by ELEVENS, 8:32 PM 11/28/2002]
Old Nov 28, 2002 | 05:14 PM
NoWorries's Avatar
NoWorries
Default Re: Is YOUR tach accurate? (ELEVENS)
Dead on. :cool:
Old Nov 28, 2002 | 05:17 PM
ELEVENS's Avatar
ELEVENS
Default Re: Is YOUR tach accurate? (NoWorries)
Dead on. :cool:
Cheater! ;) (But which one - both??!) Guys I know with the digital dash complain that they're slow to respond, like when going through the gears WOT.
[Modified by ELEVENS, 5:19 PM 11/28/2002]
Old Nov 28, 2002 | 05:23 PM
NoWorries's Avatar
NoWorries
The AutoMeter is perfect, the stock one is SOOOOOOO slow that I don't even look at it when WOT.
I don't have a decent trans governor, so I have to shift the car myself, I've been shifting about 5250 rpm, thats where the car feels like its getting slower. I'd never be able to nail that number with the stock tach, which skips 2-300 revs per refresh...
My stock tach is accurate if I'm not accelerating, within 100 revs or so. :seeya
[Modified by NoWorries, 4:13 PM 11/28/2002]
Old Nov 28, 2002 | 05:30 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
The way I figure, my tach is off by 200 RPM
http://temp.corvetteforum.net/c4/mrmojo2//shiftvid2.mpg
Old Nov 28, 2002 | 05:42 PM
VetteBabe1's Avatar
VetteBabe1
Default Re: Is YOUR tach accurate? (Mr Mojo)
90's are commonly off....my 90's tach was off by 1000rpms (high) or more across the board.
Old Nov 28, 2002 | 06:05 PM
Raistlin's Avatar
Raistlin
:nonod:
I can't vote, though. My tach is now reading ~2000rpm high :mad
ELEVENS, can you tell me a little bit about your wheels? (size, backspacing, etc) They are very :cool:
:cheers:
Edit: I found the choice for >1000 :crazy: Must of been all that bird that made me overlook it :lol:
[Modified by Raistlin, 6:08 PM 11/28/2002]
Old Nov 28, 2002 | 06:12 PM
95AquaC4's Avatar
95AquaC4
Dyno showed me being off 700 rpm!! :eek:
Old Nov 28, 2002 | 07:08 PM
ELEVENS's Avatar
ELEVENS
Hey Mr Mojo!
THAT'S THE COOLEST VIDEO, MAN!!!!
Im not big on the animated icons, but THIS time...
:cheers: :cheers: :cheers: :cheers: :cheers: :cheers:
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: Is YOUR tach accurate? (95AquaC4)
:yesnod:
Old Nov 28, 2002 | 07:18 PM
ELEVENS's Avatar
ELEVENS
Default Re: Is YOUR tach accurate? (Raistlin)
...tell me a little bit about your wheels? (size, backspacing, etc)
They're custom 3-piece FIKSE FM5's. 17x11 in the rear, 17x9.5 in the front. They were custom-backspaced to fit perfectly under the fenders (sorry-don't remember the specs). Before these, I owned silver-painted GS wheels which stuck out about 1/2" in the rear on each side :( Last week I wanted to get the centers anodyzed black, but Fikse wants $375 per wheel to anodyze (actually replace) the centers. OUCH! Not gonna happen! :cry
[Modified by ELEVENS, 7:24 PM 11/28/2002]
Old Nov 28, 2002 | 08:03 PM
scorp508's Avatar
scorp508
First gear is ludicrous.
Second gear is about an 800 RPM joke.
Third gear and higher is on.
At the track if the tires spin my MSD limiter (6300 RPM) is kicking in with the tarck still showing between 4200-4300.
Old Nov 28, 2002 | 08:23 PM
atotalnincompoop's Avatar
atotalnincompoop
mine is only accurate at idle :yesnod:
Old Nov 28, 2002 | 10:36 PM
Raistlin's Avatar
Raistlin
Thanks!
What got my attention was the fact the rears didn't stick out, and the center section has an aggresive, recessed look.
Old Nov 29, 2002 | 01:53 AM
Juliet's Avatar
Juliet
:confused: How do I tell? For a stock 87 L98 with 700 R4, what RPM should I be at for what speed? I haven't dyno'd my car or anything like that to get a calibrated comparison. Is there another way to figure out what RPM it's really running? ~Juliet
Old Nov 29, 2002 | 01:59 AM
scorp508's Avatar
scorp508
The problem with the digidash is that it only updates something like 12 times a second. Add on top of that that the liquid crystals cannot react that fast and you get interesting results in low gears.
Old Nov 29, 2002 | 02:34 AM
The Dingo's Avatar
The Dingo
CI 6-7-8-9-10 Veteran
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-‘17, '22
Default Re: (scorp508)
200rpm fast here.
[Modified by Red 90 L98 Coupe, 12:06 PM 11/30/2002]
To Is YOUR tach accurate?
Old Nov 29, 2002 | 08:59 AM
kittmaster's Avatar
kittmaster
Notice your oil pressure is kind of low under heavy accelaration. Maxing at 40 PSI at 5800 RPM's??? Shouldn't it be at 50 to 60 even under hot conditions?? I know mine is that's why I ask......??.... :confused:
Old Nov 29, 2002 | 09:06 AM
ELEVENS's Avatar
ELEVENS
Default Re: Is YOUR tach accurate? (Juliet)
Hi Juliet,
I think most compare the reading with a scanner tool or shift light. If you know your rear-gear ratio and tire size, the rpm can be calculated based upon speed, transmission gear, and a locked up torque converter, assuming your speedo is correct (here we go again!).
Cheers!
Old Nov 29, 2002 | 09:10 AM
ELEVENS's Avatar
ELEVENS
Default Re: Is YOUR tach accurate? (kittmaster)
Well, we could start another thread "Is YOUR oil pressure guage accurate"...!!!
...and speedo, and oil temp, and battery, and.........!!!!
