Transmission Mambo #5
Old Jul 29, 2020 | 07:42 AM
Customer136's Avatar
Customer136
Default Transmission Mambo #5
OK, dumb newbie question... rolling at about 10 mph in first gear in my 1994 LT1 I punch the gas, and as I happen to be in a place safe enough to look down at the stick shift I see it rises maybe an inch. Is this amount of play in the drive train normal?
Old Jul 29, 2020 | 08:07 AM
cv67's Avatar
cv67
St. Jude Donor '05
No. Check your motor mounts and see if your C beam is tight
Old Jul 29, 2020 | 09:16 AM
KyleF's Avatar
KyleF
Agreed, some drive line flex is perfectly normal, but that is excessive play in the stick.
Your 6-speed stick is actually mounted to the car. It's lower section is connected to the shift rod, unlike some other cars I have had that the shifter mounts to the casting of the transmission. To see it lift 1" is surprising.
Do you get a lot of noise in that area?
You can look at the pictures in This Thread where I changed mine to a B&M. You can see the pins/bushings that set into the receiver in the car body. 1" is close to unseating these. I don't remember there being enough room for 1" of movement. You may want to pull your trim plate and boot up to check nothing is broken in your shifter mount as well.
Last edited by KyleF; Jul 29, 2020 at 03:32 PM. Reason: Strikethrough wrong information
Old Jul 29, 2020 | 10:43 AM
ChumpVette's Avatar
ChumpVette
The ZF shifter is not mounted to the body. It is mounted to the back of the trans. The only thing that you could reasonably think is attached to the body is the upper rubber boot.
As mentioned. Check the engine mounts and the torque on the c-beam bolts. Don’t just tighten, make sure they are torqued to spec.
Old Jul 29, 2020 | 11:21 AM
KyleF's Avatar
KyleF
That is correct, upon reviewing my pictures the supports for the receiver come up from the transmission casting. It drops in from to top to this area and is connected by sleeve to the shift rod with a retaining pin.
Old Jul 29, 2020 | 12:18 PM
Krusty84's Avatar
Krusty84
C-Beam bolts are loose or wallowed out. I just made a set of DIY ZFDoc plates for my car. No more movement.
Old Jul 29, 2020 | 02:40 PM
Customer136
Thank you and all for this consensus! Last time a mechanic had the car on a lift he showed me a bolt underneath the transmission with bright metal on the shaft where something had evidently been riding up and down - believe he tightened it, but as ChumpVette suggests, maybe he did not torque it. Perhaps time to take the car to a specialist shop.
For what it's worth the shifter looks like the replacement rather than original in KyleF's link - complete with the cue ball. I've owned this car for less than a year of its 26 year history and don't know much about its checkered past.
Old Jul 29, 2020 | 10:22 PM
MatthewMiller's Avatar
MatthewMiller
This. I guarantee it's the C-beam bolt(s). I've experienced the exact same thing personally. Those are through-bolts, with nuts on the top of the C-beam. The bolts don't thread into the C-beam. So if your mechanic didn't get on top of the beam with a wrench to hold the nuts, then he didn't adequately tighten the bolts. If you use the ZF Doc plates referenced above, then you don't need to hold them with a wrench as long as both bolts on that end have been started in the threads. But anyway, get under there and fix it - don't keep driving it like this.
To Transmission Mambo #5
