Bad Day Bag Suggestions
With all that said, here's what I've got so far:
- Ratchet wrench with a full set of metric sockets
- Also have a set of star-bit sockets in various sizes (EDIT: These are Torx bits, I spaced on what they're called)
- set of 14mm, 16mm, and 17mm box wrenches
- 1 Flathead and 1 phillips head screwdriver
- RTV (orange)
- Quart of oil
- Wire stripper tool
- volt meter
- electrical tape
- a few butt wire connectors
Based on feedback here's a few more:
- Cigarette lighter powered air compressor
- pliers
- cable ties
- spare serpentine belt
- Ignition module
- gloves
- water
- battery jumper
- various fuses
- spare radiator hoses
- Duct Tape
Thanks!
Few min youre back on the road.
Also, I have free towing as part of my car insurance so covered there.
Also, bring an extra serpintine belt, extra upper and lower rad hose, 2 quarts of oil and a couple bottles of water, some zap straps and some mechanics gloves. Also make sure your spare tires is inflated or bring liter operated air compressor (if the spare is toast).
I think with those things plus what was on your list you should be able to deal with a lot of unexpected situations, that could come up.
Enjoy the trip!
A couple of wire nuts could be of use for a quick fix to get you off the side of the road.
I have not heard of the side-step bleed method.
Could you enlighten me ?
Obviously before you go you should make sure you have no leaks and all fluids are in good condition and topped off.
General road trip items: A clean gallon of potable water can be used to drink or fill your car's radiator up depending on the situation.You can get to safety on water and get antifreeze. You mentioned taking some oil, but might want to toss in some trans fluid, power steering fluid and gear oil as well. They won't go bad, you can use them later. I like the fluid fill in a can for tires as it seals and inflates in one can, but a patch kit is OK with a portable compressor. Duct tape, electrical tape, and wire ties are always good in a pinch to doctor something until you can get to a place to safely fix it correctly.
What I see common fails:
Injecotrs/MAF/ICM/ECM/CTS/TPS/O2 Sensor/Fuel Pump. It's fine if you want to carry some spare parts, but how often do they actually fail? Most of those conditions allow for some kind of limp mode to get to where you can actually get it fixed. Tough call here, I wouldn't say not to take a belt, hose, spark plug and what not with you, but you should have confidence in those items before taking off on your trip. We also don't see a lot of sudden failure of those items. Again, the focus has to be on limping to where you can fix. The biggest one I think I would be worried about is the Fuel Pump, well maybe the ECM. There is not a lot you can do to inspect their condition or predict their failure.
General tools: Regular pliers, Needle nose pliers, and one I didn't see mentioned is a set of locking pliers. Never know when you need to clamp something and hold it together. There has already been mention of most other tools, but what about diagnostic tools to help identify a problem? Fuel pressure gage, data logger/scanner, noid light? Some things to consider in addition to the hand tools.
Here is a bigger thing to consider. How is your cell phone reception along you planned route? I would plan a back up with a radio, CB, something else to call for help if you are stranded and can't get a call out.
Pump the pedal several times. Hold it down for a couple of minutes, then release quickly. (An actual "side-step" is not really necessary). Repeat if necessary.
The idea is that air in the slave cyl will rise to the top of the cyl which is where the hose comes in. At the top. The volume of the hydraulic line between the slave and master cyls is smaller than the displacement of the master cyl. So any air remaining in the slave will be evacuated to the reservoir when the pedal is released. I know it works. This was in 2017, I never re-bled the clutch , and it still worked a couple months ago when I last moved the car. Good trick to have in your knowledge base.
it stranded me the week I bought it when the thermostat stuck open. Only time that’s happened. The socket set I actually bought at the time to get it home. Rtv was necessary to seal the tstat housing back up. This was nearly three years ago and not been stranded since. I keep up with my fluids etc. too the point that I change them out once per year whether necessary or not.
It’s amazing how many things you can do with some simple tools on these cars. I figure this kit can just live in the car even after taking a trip as a safety net. I don’t want to carry too many spare parts.
