I did a search and noticed that most of you like the msd 8.5 superconductor wires.Ignition coil i think i am going to go with the hypertech.What ignition module do you like.Would a aftermarket module be any better than the old stock one?Thanks for any info
The stock setup is great up to about 5500 RPM which is higher than any stock L98 will be spinning anyways. If you decide to go with a hotter coil though, make sure to get a low resistance HEI bushing to go with it.
