Better wheel bearings?? (RACECAR)
Matt Rat.
https://www.corvetteforum.com/forums...ack-usage.html
Best way to do that is to pick up the latest issue of Corvette magazine!! Sorry...I had too. But yes they did indeed do a really nice article on our racer so its worth a look if you are in a barnes and noble anytime soon.
But in any event I can give you a few details on our steed here. Its an 84' that was in VERY bad shape when we found it. The plan was to use the car in the 24 hours of Lemons and the World racing league. So the build is pretty mild, but the results have been great, good enough that more SCCA stuff is planned next year.
Engine: 350 Chevy, 1997 truck block, Moroso oil pan, balanced, Edelbrock LO5 cam, crane roller rockers, basically stuff I had left over from stock car racing.
Trans: Doug Nash 4+3 I put the overdrive on a manual switch and added a front mounted trans cooler.
Diff: I picked up a bunch of used diffs for the car. We swap the entire center section to change gear ratios for the different tracks. 2:73, 3:08, etc!
Interior: We started out with an autopower cage, but we decided to add and move a few bars to make it better for some of my larger drivers. Kirkey Road race seat, SPA fire system, Grant detachable steering wheel, Auto meter gauges, Nerdy racing radio system. Joes racing mirror.
Body: Five star lexan windshield, Five star lexan spoiler, We made our own brake ducts and made a scoop to help the radiator get more air. My Dad deleted all the holes from the parking and running lights its not a racing hood, he just has mad skills with fiberglass!
Misc: 22 gallon fuel cell (molten metal racing mount/cage) staggered Azenis 615K on C5 Corvette wheels, HAWK pads, braided brake lines, Champion radiator
We gutted the door and moved the bars into them.
We stole the spoiler from a wrecked Toyota NASCAR. We had to narrow it, but otherwise it fits like it was meant to be on the car!
A trio of top 10s and one top 5 in 10 races so far. No DNFs.
I believe that the knuckle itself is shorter in height but that wouldn't have anything to do with a bearing.
My guess on the reason the Detroit Speed units are for 91-96 and not 88-96 is likely due to the internal tone ring versus the external tone ring for the abs. The 91-96 knuckles have a through hole while the 88-90 have a pocket and a sensor hole.
If... the bearing mounts were the same and the bearing length was the same (so you don't throw off your rotor/caliper alignment) then you could likely have a competent machine shop bore through the knuckle to make room for the X-Tracker.
I would call Detroit Speed and talk with them.
