Headlight motor question
Old Aug 4, 2020 | 03:24 PM
Alteredspeed's Avatar
Alteredspeed
Default Headlight motor question
So I have a 1986 with 2 wire headlight motors. It had he headlight solid state module installed. The head lights don’t move up or down. I have power on the yellow wire when I pull the head lights and power on the gray when I turn them off. Are they supposed to alternate ground? So the gray wire when the head lights are on is keeping like 10 volts? And I’m assuming it should switch to ground to make the headlight motors go up? Any help is appreciated.
Old Aug 4, 2020 | 04:32 PM
TommyFox's Avatar
TommyFox
Did you replace the relays?
Old Aug 4, 2020 | 07:18 PM
Alteredspeed
As stated it doesn’t have the relays it has the new style solid state controller.
To Headlight motor question
