Noise on shutdown
Old Aug 13, 2020 | 04:39 PM
rsk289's Avatar
rsk289
Default Noise on shutdown
My mate's Corvette C4 again - it has recently started to make a noise after the engine is shut off. When the key is turned off, the engine ceases to fire and as it slows to a stop there is a light rattling/whirring noise. I'm wondering if it could be some wear in a pre-engaged starter, or similar? Anyone else had this?
Thanks chaps
Roger
Old Aug 13, 2020 | 08:59 PM
CorvetteRules's Avatar
CorvetteRules
It could just be the fans coming to a stop.
Old Aug 13, 2020 | 09:07 PM
darrensls1's Avatar
darrensls1
I get a strange knocking noise when I shut my car down after a long drive. It's done it since day one so I never pay any attention to it. These car's are a little weird that way.
Old Aug 14, 2020 | 03:37 AM
rsk289's Avatar
rsk289
Thanks for the thoughts - it's quite a 'superficial' noise, nothing inside the block, I'm sure of that. It's further back than the fans and it's a new noise, not there for the last 12 years. The car doesn't get much use so I'm thinking it may be the starter - are these pre-engaged? Or do they have a throw-in Bendix?
Old Aug 14, 2020 | 04:30 AM
Chris_G's Avatar
Chris_G
St. Jude Donor '05-'06-'07
Air conditioning equalizing for $200
Old Aug 14, 2020 | 10:38 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
What year Vettes here??
Old Aug 14, 2020 | 11:18 AM
cv67's Avatar
cv67
St. Jude Donor '05
Had a horrible whining noise coming from the passenger seat area. Became single now its gone!
Old Aug 15, 2020 | 06:00 AM
rsk289's Avatar
rsk289
Sorry - '89 C4
Old Aug 15, 2020 | 06:45 AM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Auto or ZF6?
Old Aug 15, 2020 | 08:39 AM
rsk289's Avatar
rsk289
Originally Posted by FASTAZU
Auto or ZF6?
Auto.
Old Aug 15, 2020 | 03:18 PM
ctmccloskey's Avatar
ctmccloskey
Double check your cooling fans as the fan could be starting to have bearing issues, and they do like to spin down after shutdown and make more noise when wearing out.
Is the noise coming from the area around the serpentine belt, specifically the tensioner Pulley? Mine made some strange sounds before giving out completely.
I have seen branches stuck near the fans make new noises, you can pick something up easily.
Best Regards
Old Aug 15, 2020 | 05:24 PM
89bluvette's Avatar
89bluvette
5th Gear
Default Could be smog pump
My smog/air pump will make a odd noise just as my 89 is turned off after a drive could be described as a Kind of a rattle
To Noise on shutdown
