My LT4 needs new plug wires. One melted to the exhaust manifold and from the looks of them, they might be original. Other than plugs, what kind of maintenance parts and sensors should I consider for the 53k mile car that sat for the last 8 years in a garage, without running? I think O2 sensors are a good idea but what else should I consider? (All the fluids and filters are already changed.)
Also, I was planning on using a set of OEM replacement wires unless there is a reason not to.
One thing I did for preventative measure was relocate the ICM to the radiator shroud. Clean it and the heat sink and their mating surfaces, apply some new thermal paste. Extend wires and mount to shroud. Search the forum you've find some photos or I can upload some later
Honestly, I'd do the front two O2 sensors and call it a day if everything else is working right now. There's nothing on the parts market that's better quality than the OE electronics these days.
