Prom Style Computer
Old Aug 17, 2020 | 11:14 AM
jstkrsn's Avatar
jstkrsn
Default Prom Style Computer
Has anyone come up with a replacement programable computer for the old style prom computers where you have to take the prom out and have it reprogramed like I have in my 92. Had I known that when I bought it, I would have got at least a 93.
Old Aug 17, 2020 | 11:19 AM
TommyFox's Avatar
TommyFox
https://www.haltech.com/product/ht-0...rt-plug-in-gm/
Old Aug 17, 2020 | 11:23 AM
jstkrsn's Avatar
jstkrsn
Thanks, sounds a little pricy, and it only fits up to an 89. MIne is a 92.
Old Aug 17, 2020 | 12:08 PM
Nomake Wan's Avatar
Nomake Wan
That wouldn't have helped, since the 92 and 93 computers are basically the same. It's the 94-95 that are flash-reprogrammable. And the 96, but it requires a different flash method that currently costs $400+.
Haltech does have a support article about the LT1, but basically they tell you to go ahead and wire it yourself. If you have patience, that's not actually that difficult a job to do, and they do give you instructions. But it does not appear they have any plug-and-play solutions for the LT1/LT4.
https://support.haltech.com/portal/e...tispark-engine
Old Aug 17, 2020 | 04:11 PM
KyleF's Avatar
KyleF
What ECM is in a 92? I went with an EBL from Dynamic EFI for my F-Body TPI. I know later LT1/4 isn't compatible, but I have a small hope the 92 may be?
Old Aug 17, 2020 | 04:41 PM
84 4+3's Avatar
84 4+3
It can be done but I think the CCM is left inoperative...
Old Aug 17, 2020 | 04:49 PM
KyleF's Avatar
KyleF
I know EBL is available for TPI Corvettes. How did the CCM/ECM arrangement change? 92 LT1 is still OBD1, Batch Fire, 700R4. It is basically a miniram TPI with a distributor in the front rather than the rear. Although, I know the Corvette had some functions the F-Body did not. It is dang near plug and play but if the factory ECM has code for the CCM I am not sure that would be supported.
Dynamic has a list of compatible ECMs, that is why I was curious what the ECM number is and if it is listed as a "compatible" option. There is some re-pinning of the ECM harness, but it isn't bad to get one in. Then 8 frames per second data stream, data logger, and flash based memory ready to go. Works on GM .bins so there is a lot of support... all good things if it is compatible.
Old Aug 17, 2020 | 05:53 PM
JackDidley's Avatar
JackDidley
I used to burn chips for my 87. Not difficult or expensive. Is a 92 that hard to do ?
Old Aug 17, 2020 | 05:55 PM
Nomake Wan's Avatar
Nomake Wan
Not hard, but you do need the MEMCAL adapter in order to use aftermarket chips. You also need a chip burner, and chips, and know what you're doing with both. While I personally don't find any of that difficult, some might.
The ECM for both the 1992 and 1993 Corvette is 16159278.
Old Aug 17, 2020 | 06:30 PM
84 4+3's Avatar
84 4+3
Not sure, Bob lists it on the site though... you'd have P4 and it says 90-91 vettes it isn't supported.
Old Aug 17, 2020 | 06:42 PM
James93LT1's Avatar
James93LT1
Veteran: National Guard
Install a Moates Ostrich on the ECM.
https://www.moates.net/ostrich-20-th...eed-p-169.html
Old Aug 17, 2020 | 08:09 PM
stew86MCSS396's Avatar
stew86MCSS396
From: Liliha Bakery stuffing my face with coco puffs!
Since the OP is addressing 92, the only thing I find annoying is going under the hood of my 90 to change the tune. Suppose I could hook up my Ostrich but I still need a longer cable! lol
Old Aug 18, 2020 | 11:40 AM
KyleF's Avatar
KyleF
I used to push mow my grass, now I have a rider
I used to ride my bike everywhere, then I got a license
I used to talk on a phone with a cord attached to the wall... you see where I am going with this?
time has passed, technology has improved and faster data logging with flash based tuning is just quicker and easier
It would appear dynamic doesn't support a plug and play option for the 92. In which case, I would be looking at the ostrich.
Old Aug 18, 2020 | 09:52 PM
Kevova's Avatar
Kevova
You could change PCM and engine harness.to a 94-95 SFI. If you have M6 it's fairly simple. Lots of 94-95 LT1 cars including full size. Use MAF or tune it for speed density. Automatic will be more complicated because of different type of shifting. 92-93 cable.94+ electric.
To Prom Style Computer
