Vin
Old Aug 21, 2020 | 03:52 AM
jseremba's Avatar
jseremba
Default Vin
Hi Everybody,
This is the VIN 1G1YY0788F5107034 for my 85 4 plus 3. Does the 51 mean the Z51 suspension is in the car.
Thank you
Joe
Old Aug 21, 2020 | 05:12 AM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
No!
Old Aug 21, 2020 | 05:16 AM
jseremba's Avatar
jseremba
thank you!!!
Old Aug 21, 2020 | 08:18 AM
James93LT1's Avatar
James93LT1
Veteran: National Guard
VIN decoder.
https://www.corvette-web-central.com...html#1981-2013
RPO label location.
https://corvettesalvage.com/where-is...label-located/
RPO codes.
https://corvettesalvage.com/1985-corvette-rpo-codes/
Old Aug 21, 2020 | 08:27 AM
jseremba's Avatar
jseremba
Thank you
Old Aug 21, 2020 | 10:34 AM
MatthewMiller's Avatar
MatthewMiller
Old Aug 29, 2020 | 08:11 AM
slammin's Avatar
slammin
You want to read the RPO sticker to learn how your car is equipped. For an 85, if it is still in the car it is a White sticker located on the underside of the rear, left storage compartment cover (on the driver side) of the car.
Old Aug 29, 2020 | 12:14 PM
WVZR-1's Avatar
WVZR-1
Originally Posted by ihatebarkingdogs
If the sticker is gone, these pics are of the front spring, steering rack, and lower A-arms on my Original Owner, unmolested 1985 #26553 with Z51. If you car has similar identifiers, it is probably a Z51. Sway bar diameters are another clue to Z51 content. So are the wheel widths, if the wheels are original to the car, which 35 years later, they may not be.
This is likely the complete VIN for IHBD 1985 'if he posted correct last 5' - you can see the similarities of his/yours. You do need to ID components.
1G1YY0786F5126553
This should be a quite complete GM VIN CARD 'decoding info'
https://www.genuinegmparts.com/src/p...0_Vincards.pdf 1985 I believe is on page 75
Old Aug 29, 2020 | 10:54 PM
IHBD's Avatar
IHBD
Pro Mechanic
I'm not sure what the VIN of my car has to do with helping the OP figure out if his 85 is Z51-optioned or not, but if it will help, here is Dave's (WVZR-1) VIN for his 90: 1G1YZ23JXL5800653. How'd I do, Dave?
To Vin
