random tech cats
Old Nov 30, 2002 | 09:45 PM
chozen1's Avatar
chozen1
Default random tech cats
1992 coupe
I need new driver's side cat. current one is 50 % functional
random lists one on their site. DOes anyone know if it is a direct fit, or does it need to be welded? Comments on performance
Old Nov 30, 2002 | 10:05 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: random tech cats (chozen1)
I got mine from TPIS but I see they don't list one for '92 Vette LT1. You might contact RT directly to see what's up with fitment.
I did my RT cat along with front Y and TPIS cat-back so can't realy say how much gain was from the cat alone, though there was substantial gain overall.
If one is 50% you might as well do both at once; take a look to see how they're installed.
Old Dec 1, 2002 | 02:56 PM
khornet's Avatar
khornet
From: Phx/but its a dry blast furnace kinda heat AZ
It's a direct replacement. They are MUCH smaller and lighter than the factory cats. I also removed the factory mounting bracket on my ZF6 to get the cat installed.
Old Dec 1, 2002 | 04:12 PM
365ZUM's Avatar
365ZUM
Cruise-In III Veteran
Default Re: random tech cats (khornet)
Another option is Carsound cats. I believe that Chris @ Speeddemon Motorsports has the best deal on them <$100. However, they are larger than the RT cats which go for around ~$150. Both are well made products from my experience (in fact, I've heard that Carsound is the parent brand of Magnaflow). Just depends on whether you see a need for the smaller cats or not. :cheers:
To random tech cats
