code 41
Old Aug 24, 2020 | 11:13 AM
Steve Vail's Avatar
Steve Vail
Cruising
Default code 41
I have a 91 L98. I have a code 41 and no start problem. I bought a remanufactured ECM and a new distributor. the engine will start with starting on startup fluid. Also no fuel for 2 seconds. new fuel pump and all relays checked ok. Is this an ECM problem or something else?
Old Aug 24, 2020 | 11:31 AM
Nomake Wan's Avatar
Nomake Wan
Code 41 what? When you run codes, a module number is provided. Module 1 is CCM, Module 4 is ECM, Module 9 is ABS. Which module reported 41?
Did the remanufactured ECM come with a MEMCAL? If not, did you make sure to put your old MEMCAL into the new ECM? Just covering the simple stuff.
Old Aug 24, 2020 | 11:33 AM
jazfe's Avatar
jazfe
My 86 FSM states:
Ignition off
Disconnect ECM connections
Probe terminal D1, D3, D10, A12 with a test light connected to 12 volts
Light on = faulty connections or faulty mem-cal
Light off = repair open ground at circuit 450
A12, D1, D3, D10 are all circuit 450 which is ground for ECM and other items
Hope this helps
Old Aug 24, 2020 | 11:38 AM
Nomake Wan's Avatar
Nomake Wan
Originally Posted by jazfe
My 86 FSM states:
Ignition off
Hope this helps
Your 86 is completely different from his 91.
Old Aug 24, 2020 | 12:15 PM
jazfe's Avatar
jazfe
Gotcha
Old Aug 29, 2020 | 05:41 PM
Steve Vail's Avatar
Steve Vail
Cruising
Then can anyone help with my problem?
Old Aug 29, 2020 | 10:47 PM
stew86MCSS396's Avatar
stew86MCSS396
From: Liliha Bakery stuffing my face with coco puffs!
Assuming it's an ECM code, code 41 is wrong MEMCAL or possibly not seated correct. Try re-seating MEMCAL by removing and reinstalling.
Old Aug 30, 2020 | 12:43 PM
lrj975's Avatar
lrj975
did you short pins A-G to get an H 41? if so, I agree with above to reseat the memcal. ECM r&r also reseats the 4 plugs to the ECM which could help. But with replacement ECMs and distributor you seem way past that.
Do both ECMs, and both distributors, give the same conditions??
I had a H41 pop up while driving, went to limp mode, drove a mile and made it home barely. My H41 did not cause a no start condition, engine still started, but very rough. I reseated, and it went away, back to normal. I was in the ECM last year when I burned my chip so was already familiar with it.
H 41 is loss of ECM serial data communications, for those of you keeping score..
To code 41
