Hard start when hot.....
Old Dec 1, 2002 | 10:50 AM
Newbie85
Default Hard start when hot.....
Is this a common problem? It seems that the car will start fine when the engine is cold, but when it is up to temp it starts hard.. :(
Frankly, its a little embarassing at times..
Anything I can look at or do to help the situation?
Old Dec 1, 2002 | 11:25 AM
chucks88's Avatar
chucks88
Default Re: Hard start when hot..... (Newbie85)
You may have a leaky injector. You may want to consider sending them out for a cleaning and flow testing. Do you smell gas at all under the hood?
Old Dec 1, 2002 | 11:40 AM
Raistlin's Avatar
Raistlin
does it crank slow? maybe the starter could be getting hot.
Old Dec 1, 2002 | 11:43 AM
Newbie85
Default Re: Hard start when hot..... (chucks88)
Thanks for the reply. No, I dont smell any gas but I may take your advice about the injectors. It runs fine and doesnt throw any codes. I should also clarify that what I consider hard start is having to turn the key 2-3 times before it cranks.
Old Dec 1, 2002 | 02:33 PM
Mike's 86's Avatar
Mike's 86
If the engine doesn't crank I would suspect your starter may have a dead spot on the armature. :cheers:
To Hard start when hot.....
