LT1 cam selection
Old Sep 1, 2020 | 06:31 PM
Michael.parker1's Avatar
Michael.parker1
Default LT1 cam selection
I've pretty much decided on doing heads cam build on my 95 LT1 manual corvette. Looking for advice on a good cam to go with. I want something with super aggressive chop and good mid and high end power. Id like advice on whether the stock heads and intake can be machined enough to get better airflow or if im better off just buying brand new ones. also can the LT1 stock fuel system handle something like this or am i better upgrading injectors and fuel pump? along with cam selection id like to do rockers, push rods, lifters, valve springs and so on. More or less just looking to hear about good setups that function and make good power reliably. the goal for this car is 400-450 HP, not sure if this will be quite attainable with just a cam but ill try.
Old Sep 1, 2020 | 09:46 PM
Kevova's Avatar
Kevova
Popular topic. Budget? Lloyd Elliott or Advanced Induction for cylinder head porting and cam selection. You will be in the 2k.range plus tuning. With the " new top end" you will likely need long tube headers thats another 400 +. Hot Cam or similar would boost performance and shouldn't require tuning. Tuning would optimize performance.
Old Sep 1, 2020 | 10:19 PM
Michael.parker1
budget id like to keep under $4k for everything, including new radiator ill be putting in, cam, exhaust, other valve train mods ill be doing as well as the machining work and dyno tune and everything. I do plan on doing long tubes and for sure a dyno tune, id prefer not to do any mail in tuning stuff. IF anyone knows of good tuners for these cars in North Carolina id love to hear some suggestions. right now im looking into PCM of NC.
Old Sep 2, 2020 | 10:51 AM
jmgtp's Avatar
jmgtp
I’d caution a bit on wanting a super aggressive chop and basing a decision on that. Get the cam that performs where and how you want, don’t just chase a sound. You may end up loving the sound of a choppy idle and hating how it drives.
I did all of this work over last winter and into the spring. Entire valve train, cam, opti upgrade and on and on. I did all the work myself and while I have a stack of receipts I never added it up, I don’t want to know. Several thousand at least. Already had LE ported heads.
I chose the cam based on how I wanted it to perform. I wanted great drivability, a very broad torque curve, minimal cam surge, and the capability to pass emissions if it needed to (it’s exempt due to age, but laws can change). Another huge factor was sparing the stock bottom end from having to rev over what I considered too high, I set a ceiling of 6k shift points and 6100 fuel cutoff. All of that had me settled on a relatively mild cam, CC502. It performs just how I want but doesn’t really chop, though I kept stock mufflers. Louder mufflers it would have a mild lope.
My point, there is a lot to consider with a cam swap beyond idle sound.
Old Sep 2, 2020 | 11:52 AM
cv67's Avatar
cv67
St. Jude Donor '05
Good advice...lope does not equal fast...every gearhead likes it but if it doesnt perform like it sounds you will NOT be happy. Some of the strongest st cars Ive owned had good heads and mild cams. These days I like to use quiet mufflers just for the wtf factor when you nail it. Too many mouth breathers believe loud is fast and laugh at quiet stuff. Not always!
Old Sep 2, 2020 | 12:00 PM
Michael.parker1
i agree mostly, before this car I had a 2011 SS camaro 6 speed with a stage 3 TSP cam, super aggressive chop and also had the power where I wanted it. Never had an issue with how it drove. I’m looking for a cam that’ll give me the sound I want AND preform how I want, my decision will be based off of both I don’t want insane sound and bad power and I also don’t want no sound and insane power. Looking for a happy medium between them pretty much has to sound good, have good power, and still drivable on the street.
Old Sep 2, 2020 | 12:27 PM
sstonebreaker's Avatar
sstonebreaker
Call Advanced Induction. They will fix you up with ported heads and a cam that matches the heads. They got their start with the gen 2 LT1's, they really know the engine.
In my own case, I had a stock headed LS1 that the previous owner had put a Comp 234/246 cam in, that was making about 430 rwhp and 375 rwtq. I had AI port the heads and send me a similar cam, and the car made 456 rwhp and 426 rwtq. But the big change was that below 3500 rpm, the car was making over 100 ft/lbs of torque MORE than it was with the stock heads.
This is what the car sounds like:
Old Sep 2, 2020 | 12:59 PM
KyleF's Avatar
KyleF
Call Lloyd Elliot and tell him what you want to achieve. He will custom order you a grind if need be. He did my cam for ~$300 to my door.
Old Sep 2, 2020 | 01:13 PM
drcook's Avatar
drcook
Finalist 2020 C4 of the Year - Modified
Apples to oranges. A 2011 SS Camaro starts out with 42% more HP (426 vs 300). You are playing catch up to technology, 2 different engine generations/designs. There is nothing inexpensive you can do that will overcome the 16 yr advancements. Tuning is better, heads are better, on and on. GM flatly learned. The software to tune a 95 is antiquated compared to the software to tune a 2011.
Can you get good performance out of a LT1, you bet. Is it going to be fun, absolutely. But dollar for dollar, the car you used to have would respond more and be less expensive to do it. If you think that you are going to out do the Camaro you referenced (without bringing out the wheel barrow of money) you chose the wrong car.
You need to evaluate your expectations. Just the heads, headers and cam that I have bought for my '96 I am building have exceeded the budget you have. And with that it is getting in the area of the 2011 with a cam. That doesn't take into account the rockers I bought, the new injectors I am going to need, doing the tuning, etc.
Old Sep 2, 2020 | 03:04 PM
LT1inaMGB's Avatar
LT1inaMGB
https://www.youtube.com/watch?v=9Qanq74X0N8
I totally agree about AI. They can provide a cam that not only produces good hp but also has monstrous torque when combined with their heads and still have excellent street manners. They really know their stuff..
Old Sep 2, 2020 | 08:27 PM
Michael.parker1
oh i know this car will never compare to that camaro, that camaro made 500rwhp im not looking to step anywhere near that with this car, im looking to achieve 450 ish crank hp. This car is actually a college project for me, going to be tearing out the engine and checking specs on everything and then if everything checks out ill be throwing a cam in it. if its got any major wear anywhere ill start looking into 383 some more but im also on a college student budget so 383 is slightly more than what i want to spend.
Old Sep 2, 2020 | 09:34 PM
drcook's Avatar
drcook
For speaking/illustrative purposes, this kit will get you there. Gives you an idea of the cost. Add in some headers, better injectors.
https://www.summitracing.com/parts/tfs-k304-430-400
It has all those "extra" parts that add up quick. Head bolts, gaskets.
How many miles on the engine ? As long as it is all apart, if there are lots of miles, then a water pump. How about the timing chain ? A roller is $220 plus depending on which you get.
Don't forget that to pull the harmonic balancer and hub, you need to do some research on the right way to go about it. GM had a special tool.
You will hit and pass that $4000.00 mark real fast. I was surprised myself at how expensive parts are nowadays.
If you are really going down this path, the very best thing you could do for yourself, is spend a few nights running searches and reading here on the forum and other forums, etc.
To LT1 cam selection
