Time to rerplace battery cables
Old Sep 3, 2020 | 09:57 PM
85corvette4$'s Avatar
85corvette4$
Default Time to rerplace battery cables
Hi all,
Its time to replace both battery cables on my 1985 corvette and I cant determine if the negative cable connects to the back of the drivers side head below the wiper motor or to one of the bell housing bolts? I believe if ther ground cable is on the rear of the head you need to remove the wiper motor, so I hope the 1985 vette has it ob the bell housing bolt. If mine is on the head.....is it a good idea to run the new ground cable to a bell housing bolt and leave the old cable attached to the head?
Thanks for you help
Old Sep 4, 2020 | 05:50 PM
Fiberbundle's Avatar
Fiberbundle
I am not sure on an 85 but on my 90 the negative is attached to a bolt on the block just below the head. Negative cable was the easy one, the positive snaking over the bellhousing to the starter was more of a pain.
Old Sep 5, 2020 | 08:44 PM
gerardvg's Avatar
gerardvg
Hi
Is low on the pass side trans bell housing to block bolt on my 85, lets see how many responder's to this post have it there.
Old Sep 5, 2020 | 09:25 PM
383vett's Avatar
383vett
It's attached to the side of the block on the passenger side.
Old Sep 6, 2020 | 12:17 PM
85corvette4$
Hi guys...thank you all for the replies. I hope mine is also located low on the passenger side bell housing rather than on drivers side head right below the wiper motor. That is a pain in the butt to get to.. I do see other ground wires going t o a bolt on the drivers side head but they dont appear to be of a large enough gauge to be the battery ground. Will have to take a look later at the passenger side bell housing bolts to see if I see it connected there.
Have a great weekend
To Time to rerplace battery cables
