L98 Replacement fuel injectors
Old Sep 13, 2020 | 09:22 PM
aklim's Avatar
aklim
Originally Posted by Siveck
I installed a set of Bosch 3s on a friends car about 8 years ago and the lock rings did not line up. Only way to know would be to take measurements on the body of the injector. Most seem to think it will be fine without the lock rings.
My guess is that if the injector can come loose, it will be interesting to see. It sits into the rail and the rail and injectors are put into the bores. It might have a little travel but that slack is taken up when the rail is held down
