Shifters?
Old Dec 2, 2002 | 12:59 PM
MongooseLT4's Avatar
MongooseLT4
Default Shifters?
What do you guys like better Hurst or B&M, I noticed that the hurst seems to be less costly however I had a B&M on my Camaro and loved it. What do you guys think? I don't want the shifter to flex at all while in gear. Also I would like the shifter **** to sit a little lower than stock and still give a positive short shifting feel.
Thanks in advance :thumbs:
[Modified by MongooseLT4, 1:00 PM 12/2/2002]
Old Dec 2, 2002 | 01:06 PM
bogus's Avatar
bogus
Default Re: Shifters? (MongooseLT4)
this debate is about as intense as any out here...
I have a hurst and love it...
I have never driven any car equipped with a B&M shifter. So I am at a disadvantage.
From what I have read here, the Hurst is best for autocrossing and street whereas the B&M is best for drag racing.
Old Dec 2, 2002 | 01:19 PM
Autobahn's Avatar
Autobahn
Default Re: Shifters? (bogus)
How much does the Hurst run for please ?
How much of a PITA to install or how much might shop charge ?
Thanks :cheers:
:seeya
Nicklas
Old Dec 2, 2002 | 05:23 PM
MongooseLT4
Default Re: Shifters? (Autobahn)
I saw the hurst somewhere for $180 the ripper is $200-220..... I really have no idea what they would charge, it wasn't that hard to put one on my Camaro I'll guess we will see the differance :cheers:
Old Dec 2, 2002 | 06:48 PM
Tony.96LT4's Avatar
Tony.96LT4
I have a Hurst in my LT4 and love it but like Bogus have never driven a Vette with a B&M. However I have no trouble powershifting the Hurst in the quater mile. I think the B&M is a bit notchier and does well on the road courses. Just my opinion. The Hurst is not a bad install if you take your exhaust down. That really speeds up the install. Also, you can't compare the Hurst for a Camaro to the one for the Vette. It's a different animal altogether. I bought mine when they first came out $130. Hope this helps.
Old Dec 2, 2002 | 07:02 PM
Nathan Plemons's Avatar
Nathan Plemons
If you like the B&M in your camaro then you'll want the B&M in the vette. Honestly I've driven the Hurst and B&M in both the Vette and the Camaro. In both cases the hurst is only marginally better than stock IMHO. I loved the B&M for the Camaro so much that it's the reason I bought it for my Vette. I got it installed and all I could say was "damn that's short" My friend was sitting in the car with me under it, I told him I had driven the final pin home and told him to try it, he honestly thought that it couldn't possibly be right, no way it could be that short.
Sure enough it was right, it is that short, and it's a lovely thing. It doesn't flex at all, and it's short enough to allow you to use your cup holder. There is also a VERY satisfying clunk about it when you get it in gear. There's never any question about what gear you're in. Honestly though the best way to know would be to drive them both before you make your decision. C'mon to BG and I'll let you drive mine.
Old Dec 2, 2002 | 07:51 PM
rcolling's Avatar
rcolling
Here we go again :D
The B&M is a shorter throw than the Hurst and thus it is a bit harder to shift. The Hurst is what the stock shifter should have been. Still easy to shift and a shorter throw.
Both offer much shorter shifting than stock.
Old Dec 2, 2002 | 09:24 PM
RichS's Avatar
RichS
Default Re: Shifters? (rcolling)
I prefer the B&M over the Hurst. The Hurst felt too much like stock after being so used to the B&M.
Old Dec 2, 2002 | 09:55 PM
L98 DRIVER's Avatar
L98 DRIVER
has anyone tried the shortened shifter offered by
zfdoc.com
Old Dec 3, 2002 | 12:07 AM
MongooseLT4
Just ordered the B&M......cross your fingers hope its what I want :seeya
To Shifters?
