DTC 0171 and 0174
Old Dec 2, 2002 | 06:41 PM
OcalaGuy's Avatar
OcalaGuy
Default DTC 0171 and 0174
Anyone know what the cure for this problem is?
0171 Fuel Trim System Lean Bank 1
0174 Fuel Trim System Lean Bank 2
Thanks,
Jim
Old Dec 2, 2002 | 09:50 PM
RichS's Avatar
RichS
Default Re: DTC 0171 and 0174 (OcalaGuy)
The Helms says If both codes are set at the same time it could be a vacuum leak. Check for a faulty PCV, oil cap is tight and dipstick is seated properly.
Also a fuel delivery problem. Fuel filter? Bad or weak fuel pump?
Old Dec 3, 2002 | 07:31 PM
OcalaGuy's Avatar
OcalaGuy
Default Re: DTC 0171 and 0174 (RichS)
Thank you for the info.
The fuel filter was changed about a year ago and I have maybe put 3,000 miles on the car since then. The fuel pump checked OK about 6 months ago.
I will have to check on the other items you talked about.
Thanks again.
Old Dec 3, 2002 | 08:01 PM
john3154's Avatar
john3154
I had the same problem codes caused by a cracked PCV valve hose.
Old Dec 4, 2002 | 06:09 PM
OcalaGuy's Avatar
OcalaGuy
Default Re: DTC 0171 and 0174 (john3154)
Thanks for the information. I'll be checking all of this, this weekend.
Thanks again Guys
Old Dec 7, 2002 | 03:04 PM
OcalaGuy's Avatar
OcalaGuy
BINGO......
I had a chance to look for the loose line. There it was, a big huge black hose under the drivers side rail cover. It was completely off the port. The car even idles better.
I turned off the SES light with my palm pilot. Now I will see if I get any further codes.
Thanks for the help gang.
To DTC 0171 and 0174
