Running Carbs on a Root SC
Old Dec 2, 2002 | 08:58 PM
Light84vette's Avatar
Light84vette
Default Running Carbs on a Root SC
Has anybody converted their crossfire into a Carb fuel Engine instead of TBI's. If anybody has can you still pass smog?
OR if not Carbs, anybody out there put a Roots Type Supercharger on their Vette?
Old Dec 3, 2002 | 07:30 PM
Light84vette
Default Re: Running Carbs on a Root SC (Light84vette)
What the heck? Does anybody know anything on this subject? Or are all you guys just into slapping on centrifugal blowers and sissy gas. :confused:
Old Dec 3, 2002 | 09:23 PM
Light84vette
Come on. I see all the Views, why cant you people reply, the button is in the right hand corner, if you guys forgot. :mad
Old Dec 4, 2002 | 09:52 AM
JoBy's Avatar
JoBy
I put a Vortech supercharger on my Cross-Fire and kept it under the hood. 350+ hp on a compleatly stock engine.
Old Dec 4, 2002 | 09:27 PM
Light84vette
Default Re: Running Carbs on a Root SC (JoBy)
Hey Joby, would a 670CFM TB Injector unti(2bbls) have the same potential to provide enough power as a 4bbl 670CFM Carb? I think they would be the same, right?
Old Dec 5, 2002 | 12:16 PM
Chief Muktar's Avatar
Chief Muktar
I know that with a true fuel injection, such as TPI a throttle body that flow 670 CFM will outflow a 670 CFM carb by a good magin, I can't remember by how much, its a percentage like 15%. It's becuase of the throttle body is flowing only air, not the air/fuel mix like a carb. I don't know if this applies to TBI though?
Of cource this is all of my not so hot memory, so there might be some errors
:D
Old Dec 5, 2002 | 02:54 PM
MrNuke's Avatar
MrNuke
Sorry.. most of use don't have '84 CF NOR bother with the headaches of Carb conversions.. :lurk:
Old Dec 5, 2002 | 05:18 PM
JoBy's Avatar
JoBy
Actually not. The 4bbl carb is measured at 1.5" Hg vacuum and the 2bbl TBI is measured at 3" Hg of vacuum. That would translate to something like 470 CFM at 1.5" Hg vacuum.
Old Dec 5, 2002 | 06:28 PM
Light84vette
So a Carb would have more flow and potential for power than a TB Injector?onsidering they have the same 670CFM.
Old Dec 6, 2002 | 07:45 PM
Chief Muktar
See I was right, I was wrong :crazy: :D :crazy:
Old Dec 7, 2002 | 01:10 AM
Light84vette
Default Re: Running Carbs on a Root SC (Chief Muktar)
What the hell are you talking about?
To Running Carbs on a Root SC
