92 lt1 backfiring after startup
Old Sep 24, 2020 | 12:22 PM
FlyLowLt1's Avatar
FlyLowLt1
Cruising
Default 92 lt1 backfiring after startup
I just finished putting in new pistons, rods and crank into my lt1 and had it bored 30 over. After getting it back together I started it and it started well for 5 seconds or so and then started to sputter and drop to 5-600rpm and then started popping or backfiring badly. Does this consistently and wont stay running. Worried its running rich as I dont want to wash the cylinder walls during break-in.
Old Sep 24, 2020 | 03:40 PM
Kevova's Avatar
Kevova
I would start by verifying firing order. Next would be is opti correctly installed, when splines aligned optl should have slid on with little effort. If it to a little persuasion Opti could be misaligned. Grounds are always a concern they of course need to be clean and tight. Nuts bolts, and star washers not painted
