"Big" brakes
Old Dec 3, 2002 | 02:14 AM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
Default "Big" brakes
I'm slowly starting on my project overhaul. SOme thigns have been delayed due to other issues, so the list got shortened. SO far it's still going to be a 368, brakes and rims. The gears and the coilovers will have to wait till spring.
For pictures:
Here is a shot of the New Brembo 13.5 rotor (inboard) and the stock 13" rotor (outboard)
Here is a shot of the grinding that needs to be done to the steering knuckle in order to gain clearance of the wide rotors.
Here is a shot of the mounting bracket for the new 4 piston calipers. Some grinding is required to mount the bracket
And a horrible shot of the black GS rims on the rear. Not very good lighting, plus with no engine, tranny or gas in the car, thing looks like a 4x4
Let me know if you guys want any more pics of what has been done so far. I will have the calipers on tomorrow as they were being re-powdercoated.
[Modified by Jeffvette, 11:15 PM 12/2/2002]
Old Dec 3, 2002 | 02:59 AM
Cratzy's Avatar
Cratzy
Default Re: "Big" brakes (Jeffvette)
Is that an Electro Dynamics kit?
Post more pics, please... :cheers:
Old Dec 3, 2002 | 03:12 AM
Jeffvette's Avatar
Jeffvette
Default Re: "Big" brakes (Cratzy)
Not only no, hell no! I don't think Gene has even started shipping those kits yet. Let me know what you want pics of.
Old Dec 3, 2002 | 06:10 AM
CowboyNVette's Avatar
CowboyNVette
WOW those rotors are huge :eek: are you sure that grinding down the steering knuckle isn't going to ruin the intergrity of it? I really love the looks of those Brembo brakes. :yesnod:
[Modified by CowboyNVette, 6:18 AM 12/3/2002]
Old Dec 3, 2002 | 11:46 PM
Bluewasp's Avatar
Bluewasp
NoVa Events Coordinator
St. Jude Donor '14
I have brembo's and not grinding was required... hmmm
Old Dec 4, 2002 | 12:09 AM
Corvette0096's Avatar
Corvette0096
Looks good! I don't care for the grinding part. ;)
Old Dec 4, 2002 | 09:35 AM
gene284's Avatar
gene284
Unclear of the reason for the disparaging profanity?
Just checked, Electro-Dynamics has several kits for the Brembo's in stock, for the 1985-87, as well as the 88-96. Most are plated, and are engineered that they do not require any grinding to the knuckles. Will post photos this weekend if interested.
Best regards, and I apologize if you have been offended in any way in the past.
Old Dec 4, 2002 | 02:29 PM
vetracer's Avatar
vetracer
I have the Baer Alcon 14" rotors and 6-piston calipers on the front and 13.5" rotors with 4-piston calipers on the rear. Now you will be generating much more heat, and I would suggest ducting them as I did below. I have inline blower motors which pressurize the rotor hub, forcing air out of the vanes.
Old Dec 4, 2002 | 04:57 PM
TIMSPEED's Avatar
TIMSPEED
Default Re: "Big" brakes (vetracer)
VetRacer, the more and more I see of your car, the more I like it!! :eek: :cheers: :cool:
Old Dec 4, 2002 | 05:09 PM
vetracer's Avatar
vetracer
Default Re: "Big" brakes (TIMSPEED)
Thanks, TIMSPEED. I've worked very hard over the last year on my '85 and '86 corvettes. I contacted VETTE magazine over the summer and they came out and took pictures of the two cars at Firebird raceway in September. They said it would come out in the February or March 2003 issue. I don't know if they will make the cover, that would be really cool :cheers:
1985 corvette race car, 414 CID stroker motor, Callies crank, Oliver rods, JZ pistons, AFR heads, ZF 6-speed, 4:10 dana 44, coil-overs, full Guldstrand suspension, full roll cage, fire system, fuel cell, Accusump, Lexan front & rear windshield & hatch, lightweight custom hood
[Modified by vetracer, 10:21 PM 12/4/2002]
To "Big" brakes
