Diagnostic port
Old Sep 26, 2020 | 04:19 PM
Jshires's Avatar
Jshires
5th Gear
Default Diagnostic port
I’ve got a 1995 LT1. It keeps reading a check engine light and I wanted to have the code read. But I can’t find the diagnostic port. I see where it used to be mounted but I can’t find the port anywhere. Surely it wasn’t removed was it??
Old Sep 26, 2020 | 05:20 PM
firefighter12986's Avatar
firefighter12986
its prob under the dash somewhere in the area It was prob just unscrewed and never put back
in place
Old Sep 26, 2020 | 05:23 PM
Nomake Wan's Avatar
Nomake Wan
As the above poster said, it may have been unscrewed and accidentally shoved up under the dash panel by someone at some point. Remove all the 7mm bolts that hold the knee panel on (there are some on the side facing the door, and the rest are where the panel meets the lower dash), then wiggle it free slowly. Do not yank on it--the floor courtesy light is plugged into the car, so to get the panel free all the way you need to unhook it first. Then the panel will come free.
Old Sep 26, 2020 | 05:35 PM
Charsel's Avatar
Charsel
That's where I found mine, stuffed under the dash
Old Sep 26, 2020 | 05:41 PM
Jshires's Avatar
Jshires
5th Gear
Yeah I’ve already taken the panel off. I still can’t find it but I’m gonna try to crawl up in there with a better flashlight. So far I can’t find anyone to read it anyways. Apparently a 1995 has an OBD1.
Old Sep 27, 2020 | 08:09 PM
Nomake Wan's Avatar
Nomake Wan
You have two options once you do find it.
Option 1: https://tech.corvettecentral.com/201...trouble-codes/
Option 2: Buy a $50 16-pin USB-to-ALDL cable and plug it into a laptop and use free software such as EEHack to communicate with the car and check the codes as well as do real-time datalogging.
Old Sep 27, 2020 | 09:51 PM
aklim's Avatar
aklim
Does it? I thought that 96 has an OBD2 port while somewhere earlier like 93 to 95 they have the OBD2 port but it still runs on OBD1?
Old Sep 27, 2020 | 09:53 PM
aklim's Avatar
aklim
Would THIS work? The full OBD 1 version works on my 91.
Old Sep 28, 2020 | 04:19 AM
stew86MCSS396's Avatar
stew86MCSS396
From: Liliha Bakery stuffing my face with coco puffs!
My ALDL port is not connected in the stock location. Actually it's just hanging there with the 1320 BT cable hooked up to it. Idk if PO attempted to stick it under the center console but wouldn't reach/fit.
Old Sep 28, 2020 | 06:16 AM
Nomake Wan's Avatar
Nomake Wan
It would indeed, but you'd need to make sure you have something with bluetooth to connect to it. $75 isn't a bad price if you want bluetooth compatibility, but for $25 less you can get a USB cable to use with a laptop instead. All depends on how you want to handle it.
And yes, the 94-95 use a 16-pin port with the same shape as an OBD2 port, but the pinout is not the same as OBD2, and the communication protocol is 8192 Baud ALDL (OBD1).
Old Sep 29, 2020 | 07:30 AM
Nomake Wan's Avatar
Nomake Wan
Originally Posted by ihatebarkingdogs
How about use the onboard diagnostics? Nothing required except a jumper wire and the know-how to do it.
Here's a link to the text that gives you the "know-how".
Yessir, that's most certainly the first thing anyone should try before investing in a tool for datalogging and reflashing.
Old Sep 29, 2020 | 08:33 AM
aklim's Avatar
aklim
Reflashing, I'd pass unless you have some desire to mod and heavily. I'd rather have data than codes and it's cheap. 80 dollars and a smart phone we all have gives you a scanner. I carry that with me but use the other two when I am home.
Old Sep 29, 2020 | 12:01 PM
Nomake Wan's Avatar
Nomake Wan
Reflashing allows for some wonderful things even if you're stock. For example, on the autos, you can alter all the shift points and access an on-the-fly switchable shift pattern. So you can have the car shift one way on the road, and another way at the track. It lets you control MIL errors, for example suppressing the knock sensor error if the notoriously-shoddy resistor in your knock sensor fails. You can have the cooling fans kick in at lower temps to control engine temp, and have them kick out at a different speed for cruising. You can flash in code that replaces the inaccessible OBDII test code with high-speed datalogging code instead. And of course you can adjust the factory MAF and VE tables to better match your specific vehicle. And those are just the start.
You would have to actually be interested in taking your car into your own hands, which not all Corvette owners are. But you don't have to be going *****-to-the-wall with mods to get benefits from altering the code.
Old Sep 29, 2020 | 05:37 PM
aklim's Avatar
aklim
In my truck, I have the tune box you can switch on the fly but that is for a couple of tow tunes and a high idle and a ***** to the wall tune. I guess I personally don't see the point of doing all that work and the cost of the hardware for a one off deal so I would hire a programmer to do it for me but if you just want to do it, I suppose there would be some sort of justification.
Old Sep 29, 2020 | 06:20 PM
KyleF's Avatar
KyleF
I would venture a guess I installed a flash based ECM in my L98 and started tuning for about what you would pay for a programmer to do you car + Dyno time. Roughly $500, so it's a wash. I realize rates my vary depending on area, but around here a basic one off dyno tune is going to run you about $500-$1000 depending on what you have.
Until I change something else and just do the tuning update myself and if it's something major I am only out the dyno rental fee and not the programmer's time, again.
Old Sep 29, 2020 | 07:25 PM
Nomake Wan's Avatar
Nomake Wan
Because the hardware and software required to make those changes is $50? "All that work and cost of hardware" is...practically nothing whatsoever. I've tuned both my car and my dad's car. The cable has paid for itself.
If it was $400 or something you'd have a point, but this is really just not a big deal. And why use an external controller on a 4L60E when the PCM does it right out of the box? That seems silly.
Old Sep 29, 2020 | 08:13 PM
Nomake Wan's Avatar
Nomake Wan
The OP asked about finding the ALDL port so he could retrieve his codes. He never asked about tuning, flashing, laptops, bluetooth, transmission control or any of the junk you're cluttering his thread with. STFU.
I do wonder if OP has found his diagnostic port yet, thanks for reminding me!
Old Sep 29, 2020 | 10:46 PM
aklim's Avatar
aklim
It is more than $50 according to THIS article so I'm not sure. I don't know what a laptop running an older version of windows goes for since both our laptops are Windows 10. And then there is the time commitment to learning how to tune. If you are making a couple changes, maybe not so much but what to do with the hardware after you are done and not need it?
Old Sep 29, 2020 | 11:26 PM
Nomake Wan's Avatar
Nomake Wan
That article is outdated.
Cable: http://aldlcable.com/products/aldlobd2u.asp ($60; my bad, off by tenbux)
Laptop: Any (yep, even Windows 10 works just fine!)
Software: Free (TunerPro is free, EEHack is free, Flashhack is free)
But yes, you would need to learn how to tune if you want to modify the engine. But learning how to tweak isn't hard at all, and it can be used for diagnostic purposes and datalogging as well.
So again, yes, it depends on what you want to get out of it. But a $60 investment is a pittance for the amount of awesome stuff you can do with the 94-95 Corvette PCMs.
OP, have you found your ALDL wiring yet?
To Diagnostic port
