93 fuel pressure problem
Old Sep 29, 2020 | 08:48 PM
wardie's Avatar
wardie
Default 93 fuel pressure problem
my pump turns on for about three seconds when key turned to on.
when starting car fp is about 38 psi but as soon as I shut off car fp drops immediately.
I have a miss that occurs when the car has started and run for about half a minute. Opti, plugs injectors all good thinking I may have FP Regulator going bad.
Any thoughts?
Old Sep 30, 2020 | 07:59 AM
Alejandro Guerrero's Avatar
Alejandro Guerrero
Have you tried the method of getting a fuel pressure gauge and taping it to your windshield and driving around? You can rent one from places like AutoZone for free
Old Sep 30, 2020 | 08:17 AM
dizwiz24's Avatar
dizwiz24
Any thoughts?
i just solved this problem on my 93.
in my case, there was a leak in the fuel pump discharge to the outlet pipe on the fuel tank sender unit
there is a coupler and , even though i had a hose clamp, the top end of the coupler was leaking where it joins the pipe. A mity vac confirmed this when i took it apar
an extra hose clamp did the trick
this problem would make the car hard to crank, esp when hot.
Note i dont have a stock fuel pump on mine. Wabro 450 l/hr
Old Sep 30, 2020 | 08:24 AM
KyleF's Avatar
KyleF
Any thoughts?
Do you mean cranking Fuel Pressure is 38PSI or Idling Fuel Pressure is 38PSI?
Fuel pressure after you shut your car off can be an indication of some things, but usually not a big deal. Running Fuel Pressure is what matters. Some new pumps are centrifugal and don't use a check valve. To truly isolate your issue you have to crimp the return and feed lines and isolate components. Even if the fuel system can drain back on the feed side, if you still have good pressure while its running it will run fine.
As suggested above, finding a method to observe fuel pressure while driving is ideal.
If your FPR is bad, you should be getting fuel into the vacuum hose and into the manifold. Do you have a rich condition or smell gas if you pull the vacuum line off? A fuel pressure regulator is probably not causing a miss, it usually causes poor operation across the board.
Old Sep 30, 2020 | 08:25 AM
KyleF's Avatar
KyleF
Did you have trouble maintaining fuel pressure at higher RPMs?
Old Oct 5, 2020 | 07:00 AM
wardie's Avatar
wardie
FPR is bad replaced holds pressure and runs fine until you move the car then it misses.
My buddy the mechanic thinks it's a ground issue. Have gone over the electrical end of things..Plugs, wires, Injectors and a new alternator this is after verifying before replacing parts. This is a real lemon worse corvette I've had.
Old Oct 5, 2020 | 07:22 AM
wardie's Avatar
wardie
yes we did that and it led o replacing he fuel pressue regulator
To 93 fuel pressure problem
