Complete Top End / Exhaust Upgrade Write Up
Old Oct 8, 2020 | 03:52 PM
Alejandro Guerrero's Avatar
Alejandro Guerrero
Default Complete Top End / Exhaust Upgrade Write Up
Hello all! Lot's of you have helped me with various problems on my car and given lots of advice, many have also helped me plan out what performance mods to do and I know Vader has been a lot of help with that. I am making this thread so that anybody who wants to upgrade the performance on there LT1 Corvette can have a list of all parts used as well with pictures and hopefully video of the whole thing being done. I will have a running parts list of everything I use, as well as videos and pictures as things get done. This project will likely run through late December if not early January and every aspect of it will be put here. I will also be leaving any questions that come up along the way here and hopefully turn this into a all inclusive build guide for people in the future. Some parts I won't have an exact $ amount for until I purchase them, as I buy things I will move it up to the obtained parts list and add the price I bought it for. Anything in the needed list is a estimate. Right now I do have a few questions which are in parenthesis next to some of my parts. For sake of documentation please quote them if you answer so as I move parts up others will still be able to see what the answer goes to.
Obtained Parts List
1.6 Roller Rockers LUN-15345-16 Purchased for $315 from Summit Racing
3/8 Rocker Studs LUN-86000-16 Purchased for $65 from Summit Racing
Hooker Super Comp Mid Length Headers 2151HKR Purchased from forum member for $200
1996 Timing Cover, Reluctor, Hub, Crank Shaft Position Sensor Purchased for $100 from forum member
Polished Aluminum Valve Covers purchased with car
Valve Cover Gaskets Fel Pro VS 50088R Purchased from Advanced Auto Parts for $35
Custom X-Pipe done by J&J Muffler in Kansas City Purchased for $150
3.5" Stainless Steel Dual Tips Purchased from
Amazon Amazon
for $100
Fel-Pro Timing Cover Gaskets and Seals Purchased from Advanced Auto Parts for $14 Part # TCS 45956
Head Gaskets Mr Gasket 5716G for $52
Tuning cable $65 From Here
1996 Timing Cover Gaskets and Seals $15 from Advanced Auto
4.10 Yukon brand gears purchased from a forum member for $144 (includes shipping)
Bosche 3 30lb Injectors purchased from a forum member for $103.30 (includes shipping)
Needed Parts List
LE2 Heads from Lloyd Elliot $1300
227/235 565/579 110LSA Billet Cam from Lloyd Elliot for $300
Stock Intake Porting from Lloyd Elliot for $200
Tune from PCMforless.com for $200
Pushrods $150
Pushrod length checker $35
LT1 Timing Chain from Jeggs for $220 (Is it needed to replace timing chain, is it worth it to get the extreme duty one for $382?)
Version 2 Optispark from Sac City Corvette $200
Optispark Ventilation Conversion from Petris Enterprises for $130 (Are these the two things I need to convert to Cam driven opti? I would have bought everything from Petris but he was sold out of the pin driven)
Water Pump (Should I change my water pump at this point or just stick with my OEM one @102k miles)
Oil / Oil Filters
Old Oct 8, 2020 | 03:57 PM
Alejandro Guerrero
Okay so the first thing that has been done so far is my exhaust. Right now all I have done is replace the exhaust tips with some 3.5" dual tips. I also got the resonator cut out and a custom X-Pipe installed. I can't upload video directly to here but I will link a video when I get the chance to get it uploaded. Until then here is a before/after picture.
Old Oct 8, 2020 | 05:06 PM
Charsel's Avatar
Charsel
Good start with the docs, as I will be doing the same shortly. You might want to consider 1995 Impala SS Head Gaskets. From what I've read, a little thinner, and boost Comp Ratio approx.25. The increase in HP was about 14. No side effects noted in the articles. Hey Heads are off, might as well pick up more HP. Google it.
Old Oct 8, 2020 | 05:51 PM
Alejandro Guerrero
Thanks for the tip, I will do!
Update #2
The Impala SS head gasket is discontinued but Mr Gasket makes one that is 0.026 compressed so that is what I will be going with. It is also much cheaper than the Fel-Pro Corvette ones. Link added to original post.
Old Oct 9, 2020 | 08:27 PM
dizwiz24's Avatar
dizwiz24
Update #2
🖕 to GM for discontinuing that
long live the optispark 🙌
and your car is beautiful.
Keep up the good work
Old Oct 13, 2020 | 07:55 PM
Alejandro Guerrero
I have seen some people saying that doing top end on a 100k mile bottom end could be asking for trouble. Can anybody give me some $ estimations for two options. Option 1 being just tuning up the bottom end to help alleviate those problems and option 2 being a 383 stroker. Thanks!
Old Oct 14, 2020 | 09:02 AM
fredk's Avatar
fredk
I just did the top end and having 0 problems. I have just under 100,000 K
Old Oct 14, 2020 | 09:51 AM
Alejandro Guerrero
Thanks! I'm hoping I'll be able to say the same.
Old Oct 14, 2020 | 11:13 AM
vette196's Avatar
vette196
Have a machine shop look at the block....hot tank it, new rings(?).....and hopefully thats it
Old Oct 14, 2020 | 02:27 PM
wood78221's Avatar
wood78221
Where did you get the rear decals (Corvette)?
Old Oct 15, 2020 | 04:14 PM
Alejandro Guerrero
They were actually on there when I bought the car, if I see some for sale somewhere I will let you know though!
Old Oct 21, 2020 | 03:56 PM
Alejandro Guerrero
Are LS7 lifters still the standard for upgrading? If so does anybody have the current part # for them?
Old Oct 27, 2020 | 04:20 PM
Alejandro Guerrero
Hello everybody, this will be the first major update to the build thread. I have almost finished taking everything out that needs to get shipped to Lloyd Elliot. The big thing right now is getting to the head bolts that are under the exhaust manifold. I am doing headers anyway so I just gotta figure out how to get it out. Here are some pictures
My write up will get much more detailed and all for the putting it together process. Taking stuff apart is easy. I would just suggest that your LABEL EVERYTHING. Every screw and connector and bolt should be labeled.
Old Oct 27, 2020 | 04:45 PM
ChumpVette's Avatar
ChumpVette
Just remove the exhaust manifolds throw them in the trash and clear out some room.
Use this thread as a guide. https://www.corvetteforum.com/forums...long-pics.html
Old Oct 27, 2020 | 04:48 PM
vette196's Avatar
vette196
Don't throw them away, a poor man's exhaust improvement for L98 guys ($100+ on ebay)
Old Oct 27, 2020 | 05:37 PM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
check out my f/s thread, you may be interested in some of the items.
https://www.corvetteforum.com/forums...-lt-parts.html
Needed Parts Lis
the crower cam has 221*.230* duration @.050 and .525/.545 lift w/1.5 rockers.
with your 1.6 rockers the lift is .560/.581
114 lsa will give better driveability at low speeds
not listed is a cloyes tru roller timing set for the 95-96 lt1/lt4. installed on an engine that never was fired up. $150
meziere electric motor on a new water pump body that has less than 500 miles on it
Old Oct 27, 2020 | 07:12 PM
Alejandro Guerrero
That is the plan! I already have a set of mid-length headers I plan on putting on it. I would have gone long tube but I got a set of Hooker Super Comps for 367 header + ceramic coating so that's what I'll be using for now.
To Complete Top End / Exhaust Upgrade Write Up
Old Oct 27, 2020 | 07:47 PM
Alejandro Guerrero
Oops. Looks like I'll be adding a new brake line to the list of things
Old Oct 27, 2020 | 08:34 PM
Alejandro Guerrero
I might've fucked up. I used a 6 side wrench for this bolt and somehow still managed to round it. Does anybody have any ideas on how I can recover from this?
Old Oct 27, 2020 | 08:47 PM
Sleazy Rider
vice grips. i may have a pair of banjo bolts for the waterline but will not be able to look for it for a couple days. have eye surgery in the morning.
