Is Vendor Steering Me Correctly?
Old Oct 12, 2020 | 09:27 PM
RADRLUV's Avatar
RADRLUV
Cruising
Default Is Vendor Steering Me Correctly?
Hey team. First time post so please be gentle with me. I am seeking an ECU for my 1989 C4 with auto transmission. To my surprise, I found one that was "In Stock" and so excited that I immediately jumped on it. After I placed the order I started looking at the details (yeah, I know, kinda backwards) and noticed that it says that it replaces OE part #1227747. I have not yet pulled my existing ECU but everything that I have read seems to indicate that my part number should be 1227165. From what I could tell, it seems like the 1227747 is for manual transmission cars not for my automatic. I called back to the vendor and he did some checking and came back and said that "yes" his part W0133-2204705 (1227747) was a match for part number 1227165. I am still skeptical. Are there any ECU gurus out there that can clarify for me? Many thanks in advance.
Old Oct 12, 2020 | 09:46 PM
s carter's Avatar
s carter
A brief slide around on internet of the part #1227747 came back as pick-up truck and Astro Van so I'm sorry to say it to makes me nervous and not your part, My local supplier that I use shows this
https://corvetteparts.com/item/rebui...6-1989#details
. Ebay shows some and I'm sure Mirrock will probably have one used
Rock even is showing a limited number of them
AUTO zone even sell them
Old Oct 12, 2020 | 09:53 PM
Nomake Wan's Avatar
Nomake Wan
http://www.gearhead-efi.com/Fuel-Inj...Information-42
This ECM was used in 1987 to 1991 C/K Truck, Van, 4.3L, 5.7L, 5.0L & 7.4L engines.
http://www.gearhead-efi.com/Fuel-Inj...Information-6E
1989 Y & F CAR 5.0L & 5.7L
They're totally different ECMs. I can find nothing to suggest that you can use the code from 1227165 on 1227747.
Old Oct 12, 2020 | 09:59 PM
jazfe's Avatar
jazfe
I have a 86 manual trans and my computer is 1227165.
From what I understand the 86 - 89 computers are all the same. I believe the chip is where the difference of auto/man trans is stored.
Old Oct 12, 2020 | 10:03 PM
Nomake Wan's Avatar
Nomake Wan
This is true for the Corvette, yes. The physical computer on the Corvette is the same between 86-89, and all 86-88 can be updated to 89 code by altering the code on the MEMCAL and making a few other minor changes.
But it's not true outside of the Corvette, which is where the problem lies.
Also, for OP, did you really need to buy a new ECU? SIA Electronics can professionally repair your existing ECU if you have one, and that's the route I'd go, personally.
Old Oct 12, 2020 | 10:32 PM
RADRLUV's Avatar
RADRLUV
Cruising
Thank you very much. You are confirming my suspicions. I appreciate your time.
Old Oct 12, 2020 | 10:34 PM
RADRLUV's Avatar
RADRLUV
Cruising
Yep. I think I need to cancel and check the other sources that you guys mention.
Old Oct 12, 2020 | 10:37 PM
RADRLUV's Avatar
RADRLUV
Cruising
Thanks, jazfe!
Old Oct 12, 2020 | 10:39 PM
RADRLUV's Avatar
RADRLUV
Cruising
Thanks team. You have confirmed my suspicions. I have what I need for now. It is great to have such resources!
Old Oct 12, 2020 | 10:45 PM
RADRLUV's Avatar
RADRLUV
Cruising
Thanks, Nomake Wan. I kinda want a spare. It seems that these ECM's are becoming scarce. I just got this '89 but it only has 16K miles so I hope to keep it a while. Right now it has an ignition issue that I would like to see if the ECM fixes and then keep the original as a backup. The previous owner had tried several fixes for the long cranking time on start up and the shop that I took it to tried a few more things but concluded that it was likely the ECM. I hate to just throw parts at it but I thought it would be nice to have that spare anyway.
Old Oct 13, 2020 | 01:55 AM
stew86MCSS396's Avatar
stew86MCSS396
From: Liliha Bakery stuffing my face with coco puffs!
Definitely 1227747 is a truck TBI ECM. ^^^Did you check that your fuel pump relay is working? If the fuel pump relay is bad, your fuel pump won't turn on until the ECM sees oil pressure.
This is one for the dart board...is the memcal stock for your 1 year cold start injector delete?
My '90 seemed to do the same and was attributed to having Bosch III injectors. Changing the battery offsets in the tune seemed to make it worse so I increased the frequency of crank multiplier in the tune. YMMV
Old Oct 14, 2020 | 06:41 PM
RADRLUV's Avatar
RADRLUV
Cruising
I apologize for the slow response. I agree this is one of those dart board issues. I replaced the fuel pump relay along with the coolant sensor but no effect. The fuel pump and injectors are new but the issue is that they were replaced about 5 years ago but only have about 2000 miles on them. The tech shop says that the injectors appear to be working fine. I am concerned that old gas may be impacting the ignition process. But then again, the ECM seems like it could be a culprit. I just purchased this car about 2 months ago so I have not yet found a C4 guru in my area (League City, TX) that I can work with to get it resolved. Thanks so much for clarifying that the 1227747 is not correct. I have cancelled that order and purchased the 1227165 unit. Please feel free to give any additional advise you can think of.
Old Oct 14, 2020 | 06:49 PM
Fiberbundle's Avatar
Fiberbundle
You mention old gas! How old? If the car only has 2000 miles in 5 years that is a tank full a year. I would empty the tank, make sure the lines are clear, install a new filter and troubleshoot after that is taken out of the equation.
Old Oct 14, 2020 | 07:58 PM
RADRLUV's Avatar
RADRLUV
Cruising
Agreed, I think is the cheapest and simplest next step too. Thanks for taking time for me.
To Is Vendor Steering Me Correctly?
