Cold Catalytic Converter?
Old Oct 13, 2020 | 10:55 PM
kael's Avatar
kael
Finalist 2020 C4 of the Year - Unmodified
Default Cold Catalytic Converter?
I'm aware one of the items that can diagnose a cat is its temperature at the inlet versus the outlet. The outlet should be hotter due to the chemical reaction. If the outlet is cooler, this indicates no reaction and the cat is bad.
Or is it? What else might cause a cat to go cold, from the engine? Too lean? Coolant leak?
Old Oct 17, 2020 | 04:40 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Not sure about cat temp vs condition.
Good test is remove O2 sensor ahead of cat and check for excessive pressure. If no excessive pressure then cat is "fine", IMO.
Old Oct 17, 2020 | 05:25 AM
drcook's Avatar
drcook
Finalist 2020 C4 of the Year - Modified
https://www.walkerexhaust.com/suppor...c-testing.html
note that in the article it says newer vehicles with a good tune can experience only a 20 deg difference and that there are other variables that can affect temp differences
is there anywhere around you that can perform a sniff test for free ? your profile doesn't say where you are at
Old Oct 18, 2020 | 10:50 AM
kael's Avatar
kael
I'm after any problems that might cause the cat temperature difference to be backwards even though the cat is good.
To Cold Catalytic Converter?
