Brake Bleed Question
Thanks!
Bench bleed the master, install it, gravity bleed lines until they are dripping, then bleed with pedal.
If you have a pressure or vacuum bleeder - obviously use that.
If I am indeed correct and you're talking about the '96, the procedure is to first bench bleed the master cylinder, then bleed the 'normal' brakes (Right Rear, Left Rear, Right Front, Left Front), then attach a diaphragm-style pressure bleeder to the master cylinder and use a Tech 1 with the Bosch ABS cartridge or a Tech 2 to run the automated ABS bleed procedure.
However, I should note that it's only necessary to do this if you notice the pedal not functioning correctly or the ABS not functioning correctly when activated. The Bosch 5 ABS installed in the 95-96 Corvette is completely isolated from the regular brake hydraulic circuit, as opposed to the earlier systems. It only interacts with the brake hydraulics when active. So under normal circumstances, it's not necessary to bleed the ABS when you bleed the brakes or replace the master cylinder.
I hope that your new rubber lines will have a stainless braided jacket on them. The SS braided rubber hoses give a better firmer pedal feel in my opinion. Also be very careful when you buy the new rubber lines as they need to be D.O.T. Approved for use in the United States, they should have a tag on them. If they are not approved and there is an accident it would be problematic. Cheap insurance...
I have a C3 and a C4 and flush them every five years. I use a Phoenix Reverse Bleeder to push the fluid and the air UP the lines and out at the Master cylinder. It can be messy the first time but it gets better. This system gets all the air out in one action. The pump has saved my butt on my Wife's old Chevy pickup with a five speed and hydraulic clutch. It is one of the only tools that makes bleeding less work and helps flush the brakes quickly. I can flush the brakes in less than an hour on either Corvette.
A fellow Corvette Forum member sold me his Snap On MT2500 and it has been great for working on the OBD1 Corvette. I understand that Snap On made a cartridge that is specifically for the Bosch ABS systems used by GM. I have been trying to get my hands on one but they want a lot of money for them. It is supposed to troubleshoot and help bleed the system. Somewhere I read that when the Corvette is first started the ABS will cycle and be ready for action.
No, your '92 ZR-1 uses the Bosch 2U ABS, which does not have an auto bleed procedure, and uses a prime pipe connected to the brake master cylinder. The procedure is completely different from the procedure for the 1995-1996 Corvette.
You still should bench bleed the master cylinder. However, after installing the master cylinder, the very first thing you must do is bleed the prime pipe by using the bleed screw on the ABS unit in the driver's rear storage compartment, the one behind the driver's seat. Expose the bleed screw, attach a clear tube and insert the other end into a container with the end submerged in brake fluid as you would bleeding a caliper. Simply opening this valve should allow fluid to flow without touching the brake pedal. Keep the bleeder open until no more air appears in the fluid. Make sure to keep the master cylinder reservoir full during this process or you'll have to start all over again. Close the bleeder once the fluid is clear. Once the prime pipe is bled, then proceed to bleeding the brakes at each corner (Right Rear, Left Rear, Right Front, Left Front).
