LPE219 cam
Old Dec 4, 2002 | 12:01 PM
devilfish's Avatar
devilfish
Default LPE219 cam
Does comp cam do a cam that is close or a little "more" then the lpe 219 cam? And what lift does that have?
Old Dec 4, 2002 | 12:06 PM
scorp508's Avatar
scorp508
Comp can grind you anything you want.
As for the 219 it has .525/.525 lift with 1.5 rockers and .560/.560 lift with 1.6 rockers.
Old Dec 4, 2002 | 12:32 PM
vader86's Avatar
vader86
Default Re: LPE219 cam (devilfish)
CC will have just about anything you can think up on the shelf. If they dont, theyll grind it for you.
Old Dec 4, 2002 | 04:31 PM
devilfish's Avatar
devilfish
Default Re: LPE219 cam (vader86)
ok but what do they have on the shelf that is like the lpe 219?
Old Dec 4, 2002 | 05:47 PM
vader86's Avatar
vader86
write down the specs on the 219, and call them, theyll have something
Old Dec 4, 2002 | 05:59 PM
gtsyellow's Avatar
gtsyellow
if you want a 219 why don't you buy one? :lol: in all seriousness what rpm do you intend to run the motor to? there xtreme lobes are just wonderful & a 224/224 cam or 230/230 cam would be extremely easy to create if you want a single pattern grind. i had them do the cam in my sig & it peaks right around 6000rpms & i shift about 6600.
Old Dec 4, 2002 | 08:01 PM
Corvette0096's Avatar
Corvette0096
Default Re: LPE219 cam (gtsyellow)
I think the question should be, What intake are you going to run.
SkarodoM's Avatar
SkarodoM
I'd call several places.. someone is bound to have something that fits just right, and whether its a shelf grind or not, it shouldnt take long to get :).
Comp, Crower, Isky, Ultradyne, Reed, etc. all probably have something that'd make you happy.
Old Dec 4, 2002 | 08:17 PM
gtsyellow's Avatar
gtsyellow
Default Re: LPE219 cam (corvette0096)
great point, ole fishy has considered every option under the sun in the past few months & then some.
Old Dec 4, 2002 | 09:40 PM
vader86's Avatar
vader86
exactomundo
Old Dec 5, 2002 | 05:01 AM
devilfish's Avatar
devilfish
The probleme is this country, Sweden. We only got that much when it comes to "on the shelf stuff".. And to order stuff from USA is expenisve, a axampel, my firend order 2 heads from AFR, they where around 20kg and he payd $200 for the shippment only, then its extra tax on the stuff when it comes in to the country. I whant to keep my cost down. And I hade my plan pretty clear on what to do on the car. BUT when I started to look for the parts I noticed that it whsaent so easy that I thougt of. You guys are lucky living in the usa of a..
SO my plan where this.
lpe219 cam
superram
ported 113 heads
headers
1,6rr
But it might look like this for now
lpe 219 cam ( or a similar comp cam )
ported 113 heads
headers
ported stock tpi with 3" siamesd runners.
Then add superram later.
THanks for all your help so far guys
:thumbs:
REgards
Old Dec 5, 2002 | 03:14 PM
gtsyellow's Avatar
gtsyellow
your on the right track, either combo would work well..not much else to say really :thumbs:
Old Dec 5, 2002 | 11:43 PM
The Dingo's Avatar
The Dingo
CI 6-7-8-9-10 Veteran
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-‘17, '22
I feel your pain about shipping (and exchange rate, and import duty, etc). FWIW, I have found that dealing with vendors that provide you with two receipts for "shipping purposes" works quite well in some cases...;)
Old Dec 6, 2002 | 09:19 AM
Cratzy's Avatar
Cratzy
Default Re: LPE219 cam (Red 90 L98 Coupe)
How do you do that?? :thumbs:
Sorry for hijacking this thread, but I am from Sweden too (and I know Devilfish a little so I know that he wont be upset
Old Dec 6, 2002 | 10:10 AM
The Dingo's Avatar
The Dingo
Default Re: LPE219 cam (Cratzy)
Cratzy and devilfish you have IM's. Sorry for not posting here but I'm paranoid.
Let me know if you guys don't get the IM's. :thumbs: :)
Old Dec 6, 2002 | 01:44 PM
BLUE ONE's Avatar
BLUE ONE
They will do it if you ask them ;) :thumbs: ;)
Here i have even payed duty on the shipping cost @22.5%
Life would be so much nicer if i lived in the states, or travelled there regularly
I would also be a lot richer :lol:
Old Dec 7, 2002 | 03:20 AM
The Dingo's Avatar
The Dingo
Default Re: LPE219 cam (BLUE ONE)
Same here, customs nails you for the TOTAL PACKAGE COST including shipping... :rolleyes:
Sorry for the unintended hijack devilfish. :chevy
Back to the topic at hand, has anyone else got cam advice or experience here?
[Modified by Red 90 L98 Coupe, 6:23 PM 12/7/2002]
To LPE219 cam
