96 vacuum line diagram
Old Oct 29, 2020 | 02:06 PM
Stevenmacc43's Avatar
Stevenmacc43
6th Gear
Default 96 vacuum line diagram
has anybody got a good readable diagram for the vacuum lines (cruise, hvac, etc) for a 96 c4 lt1?
Old Oct 29, 2020 | 04:41 PM
TiIngot's Avatar
TiIngot
That's the best I can do. Good luck.
Old Oct 29, 2020 | 08:38 PM
Nomake Wan's Avatar
Nomake Wan
The factory service manual for your car is available from RockAuto for $20. If you plan on doing all your own repairs and maintenance it's worth every single penny. Find it under 'Literature' at the bottom of that section. I'd help you more but I don't have the '96, only the '94-'95. Best of luck!
Old Oct 30, 2020 | 09:44 AM
TiIngot's Avatar
TiIngot
WOW - I have had my factory shop manual since 2001 and I think I paid over $100 for it back then. The $20 number seemed too low until I checked. But it is a CD that appears to contain the factory shop manual on it!! Nice. My paper book is beginning to fall apart and I am not a serious gear head that uses it a lot.
Old Oct 30, 2020 | 10:41 AM
drcook's Avatar
drcook
Finalist 2020 C4 of the Year - Modified
Here are 2 printable PDF's for routing. HOWEVER, these are not all the lines. There are other lines and you really should get the FSM
File Type: pdf
File Type: pdf
To 96 vacuum line diagram
