1984 Corvette hard start cold
Old Oct 30, 2020 | 06:08 PM
19661984's Avatar
19661984
2nd Gear
Default 1984 Corvette hard start cold
New pump relay fuel filter TPS adjust if battery is 13 volts will start aways turns over good if is 11.5 volts won,t start put a little gas in injectors starts good It always tries fires a little once in awhile on warm day will start in AM HELP Thanks Jim
Old Sep 21, 2024 | 12:10 PM
billybobbob's Avatar
billybobbob
Have you checked for fuel pressure when key is first turned on?
Old Sep 22, 2024 | 06:08 PM
Sabre34's Avatar
Sabre34
Moderator
St. Jude Donor '06 thru '26
OP hasn’t been active on the Forum for four years. Thread closed.
To 1984 Corvette hard start cold
