Simple IAC Valve Question
Old Dec 5, 2002 | 10:19 AM
OleDog's Avatar
OleDog
Default Simple IAC Valve Question
Doing a TB bypass and cleaning. So far so good. Removed IAC and cleaned.
Now getting ready to set the minimum Idle speed. According to the book
"disconnect the distributor set-timing connector" Is that the same wire you disconnect when you time the car? The book calls that the "Electronic Spark timing(EST) connector. If its not the same connection whats the correct connection and where is it?
Thanks Guys
Old Dec 5, 2002 | 12:18 PM
OleDog's Avatar
OleDog
Default Re: Simple IAC Valve Question (OleDog)
C'mon guys, this should be a no-brainer for you. I gotta get this car back together today. Tomorrow I'm taking out the new 'flavor-of-the-week' ,she's not going to be impressed If I pick her up in the minivan (hehe).
OleDog :D
Old Dec 5, 2002 | 12:57 PM
Mike263's Avatar
Mike263
Thanks Guys
Yes, it's the same connector that you disconnect to set the base timing.
Old Dec 5, 2002 | 03:32 PM
OleDog's Avatar
OleDog
Default Re: Simple IAC Valve Question (Mike263)
Thanks Mike. I always second-guess myself when it comes to the vette.
Old Dec 5, 2002 | 06:18 PM
jmr302's Avatar
jmr302
There's a nice article in the Tech Tips section about this very topic.
To Simple IAC Valve Question
