Speed Bleeders
Old Nov 14, 2020 | 09:46 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Originally Posted by Hawkeye56
Thank you so much for the details. I would have never thought of pushing the pads open to drain the bores. To open the pads is it best to remove the calipers and then reinstall so they can refill or can it all be done with calipers attached.
Thanks again for the tricks to your trade.
Thanks Hawkeye56
Originally Posted by Nomake Wan
Same way as if you were going to replace the pads with new. Either use a C-Clamp on the center of the old pad to push the pistons flat, or use a pad spreader tool inside the caliper to compress the pistons. Either method requires removal of the calipers, which thankfully is a 30-second job on our cars.
No.
You do not need to remove the calipers to push the pistons in. You can do it with the calipers ON, one of several ways. Here are two ways:
1. You can use a C-clamp such that one side is on the "back" of the caliper, and the other runs through the piston clearance hole/slot in the front to push against the outer pad. The caliper will slide toward the wheel spokes (if the wheel were still installed) and push the pistons in.
2. You can simply use a pry bar, screw driver or some device to pry, and pry against the caliper to either slide the caliper "outward" -toward the wheel spokes, if they were on there, OR, get the device between the rotor and inner pad and simply push the pad and pistons back in.
3. This one takes some strength, effort but can be done on 'Vette and other car calipers. Simply wrap on hand around the back of the caliper and muckle on to it good...use two hands, if you can, then PULL the caliper outward hard. If you really give'r hell, you can slide the caliper out, bottoming the pistons in the process. Sometimes it helps to sort of "tweak" the caliper to the left and right to sort of get one piston moving at a time...wiggle it back and forth w/your two hands.
Removing calipers would add significant time to the "bleeding" process...so I don't do it. I compress the pistons with the calipers on the car.
Old Nov 14, 2020 | 09:49 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Originally Posted by drcook
An old trick I learned a long time ago is to whack the caliper with a rubber mallet. If there are any air bubbles adhering to the inside, the shock will break them free and allow them to float up to the bleeder.
That is a good trick. Doesn't have to be a rubber mallet. But it works. You can actually see bubbles come out after tapping the calipers, sometimes.
Again, I don't waste time w/the bleeder hoses...it's a waste of time.
Old Nov 14, 2020 | 10:22 PM
Vette5311's Avatar
Vette5311
Well, I have to respectfully disagree,
I have used/put speed bleeders on 3 cars including my 66 Corvette and never had a bit of a problem.
All worked well as advertised if the directions are followed correctly.
Turned the whole ordeal into a one man operation and got all the air out.
Old Nov 14, 2020 | 10:30 PM
Nomake Wan's Avatar
Nomake Wan
Originally Posted by Tom400CFI
No.
That...is certainly a method. I wouldn't do it, but to each their own. Yanking the caliper is just pulling the c-clip and pin so...yeah.
But yes, just using a c-clamp to force the caliper towards the bracket to compress the pistons is certainly another way to do the same thing.
Old Nov 14, 2020 | 10:34 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Why wouldn't you do it? What's the diff between using a C-clamp w/the caliper off and using a c-clamp with the caliper in place? The diff is that w/the caliper in place, pushing on the backing plate of the outer pad won't damage the pad, while pushing on the face of the inner pad, could (though it's not necessary) damage the inner pad. What am I missing?
Old Nov 14, 2020 | 10:50 PM
Nomake Wan's Avatar
Nomake Wan
Mostly that if I'm bleeding I'm probably replacing pads too (and have a spreader tool for the calipers). Just a difference between how you've done it and when you primarily bleed, versus how I've done it and when I primarily bleed. No offense intended.
Old Nov 14, 2020 | 11:19 PM
Patsgarage's Avatar
Patsgarage
If you're not interested in spending the money or having another thing in your garage....you can do the same thing in the same time w/o a power bleeding system.
How ?
NVM
Old Nov 15, 2020 | 01:01 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Originally Posted by Patsgarage
How ?
NVM
From post 15....
There are numerous ways in which you can speed up the process dramatically:
1. Siphon out all the fluid from the reservoir, then fill and gravity bleed. Should only take a couple minutes for the new/fresh fluid to make it to the calipers/bleeders.
2. Pump the pedal. Open one or more bleeder, pump the pedal until you get fresh fluid to that or those calipers....wait a minute for the caliper to fill and bleed, close the bleeders. Wait...WHUT? That's right, you can open a bleeder or several and pump the pedal by yourself (no helper). Yes you'll draw some air back into the caliper on each pedal release, but over all, it's a net gain and you're moving fluid from the res, down and out the calipers....fast. When you're done pumping, there will be some air drawn into the calipers on your last pedal release...that's O.K. Wait about 20 second or so and the caliper will have filled and be bled out. Easy.
3. Compress the calipers all the way. Siphon out the fluid from the res. Fill with new fluid, w/o opening any bleeder, pump the pedal to move the pads back out to the rotors. You've just changed ~90% of the fluid in the system, fast.
Bonus (for all bleeding methods):Always compress the calipers all the way before starting. Why? Think about the volume of fluid in the caliper bore(s) (large volume). Think about that compared to the volume in the lines (small). You can bleed out the system all day long and are you really replacing all the fluid in the caliper(s)? No. The brake line typically comes in to the bore near the top...near the bleeder. So while some fluid is being replaced, most is likely not, and just stays in the caliper. Especially true in multi piston calipers. SO...push the pistons all the way back in, then bleed how ever you chose to, then pump the pedal to move the pads back to the rotor....and you're filling the bores with fresh fluid.
I do this stuff for a living, so I want the fastest, easiest, best way to do it with the least help and the least expensive tools. Once the wheels are off, I can bleed out my 'Vette's brakes in about 10-15 minutes with no help and no tools other than a 10mm wrench and some catch buckets. Hope this helps.
Old Nov 15, 2020 | 01:23 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
I was on that program too, for a while when I was doing more track days; pads and fluid at the same time. With less track days, pads last 'too long' now.
Old Nov 15, 2020 | 11:41 AM
aklim's Avatar
aklim
I like Motive Products unit. I have different adapters for different vehicles. Flushing brakes is one of those things I dedicate a day to. Suck out the reservoir and put fresh fluid in, use the pump bleeder, jack up the car and let the fluid fly into a pan, one caliper at a time. Having that for 5 vehicles, and doing it manually with 2 ATVs and a bike and a trike was pretty much a day job. Since it is done once in 2 years, one day isn't that bad. I synched all of them since 3 of the vehicles were MB and the spec was 2 years, I did everything that day plus the Excursion and the Corvette and the toys.
Old Nov 15, 2020 | 11:43 AM
cv67's Avatar
cv67
St. Jude Donor '05
Same here, they are foolproof. Buy the good ones not the cheap knock offs.
Best brand was Russel think they got bought out by someone dont know the current name. (Earls?) Tried the traditional methods on my Z could not get rid of the spongy pedal. Those cured it the first try. 20 min 1 man bleed.
If you dont have anyone around to help those are the answer
Old Nov 16, 2020 | 11:50 AM
ctmccloskey's Avatar
ctmccloskey
Nobody mentioned the Phoenix Reverse Bleeding system.
Air wants to go up so why push the fluid down? The Phoenix pushes the fluid up from the caliper back into the master cylinder. It gets all the air out in one effort. I can do a whole Corvette in a half hour with this tool.
I have the Motive Pressure Bleeder and the little bleeders that screw into the caliper and act like one way valves. I put them all aside and exclusively use the Phoenix Reverse Bleeder.
The C4 has that the "Rear" loop of the brake system had a large air trap built into it. Pressure was the only way to get over the hump in the lines.
The Rear Brakes are "one" in the eyes of the ABS system on my 1988 C4. I tried gravity for fun and after a day it still had not drained out of all four calipers.
Old Nov 16, 2020 | 12:11 PM
  #33
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Wait, so you spent money on this tool....and it still takes you a half hour to get the job done? What am I missing here? What's the benefit of it?
I'm thinking that something went badly awry there. Doing the rears should have taken a few minutes. Some pedal pumping would have likely sped things up dramatically.
Old Nov 18, 2020 | 04:47 PM
  #34
ctmccloskey
With the Phoenix Bleeder it is much easier to bleed all four wheels and do it quickly by Yourself. The system works better by pushing any air up and out of the system.
It works and it works better than other bleeding systems for Harry Homeowner.
I tried the gravity drain of the brake fluid on my 1968 C3 and it did not get all the air out of the calipers. With the Phoenix it is a simple operation as you put new fluid in down below and push all the old fluid up to the M/C where it is sucked up with a turkey baster.
Old Nov 18, 2020 | 05:31 PM
  #35
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Copy that. My method (if you'd taken the time to read it) is also "by myself". Takes about 10-20 minutes. Hard to beat that, I feel, which is why I shared it. Cheap, fast effective.
Old Nov 18, 2020 | 06:54 PM
  #36
Hawkeye56's Avatar
Hawkeye56
Using the Phoenix system and pushing the fluid in reverse, I would wonder if this system could cause ill effects in the ABS system.
I will probably do the gravity bleed as it is very close to how the manual tells you how to do it.
Thanks for your post though, I am always open to different ways to complete the job.
Thanks Hawkeye56
Old Nov 18, 2020 | 07:00 PM
  #37
cv67's Avatar
cv67
St. Jude Donor '05
Tom if you do the gravity method and use a clear hose..if theres no air left and (immersed in a jar of fluid) will pumping it help things along? With my luck Id still somehow get air in there.
To Speed Bleeders
Old Nov 18, 2020 | 07:01 PM
  #38
aklim's Avatar
aklim
Thanks Hawkeye56
Question I have is if you push it in reverse, IS IT POSSIBLE that you are pushing crap back into the ABS area?
Old Nov 18, 2020 | 07:15 PM
  #39
Nomake Wan's Avatar
Nomake Wan
Not on a 1995-1996 vehicle as their ABS circuits are physically separated from the main brake hydraulics. You cannot push crap back up through it, nor can you push new fluid into it from the master cylinder. That's why in the FSM for 1995-1996 it tells you that any time you need to bleed the ABS, you must use a Tech 1A with the Bosch ABS cartridge, or a Tech 2. The tool will actuate the appropriate solenoids on the ABS unit to connect them to the brake hydraulics so they can be bled.
On the earlier systems, it's possible but not likely. The ABS/ASR should still be separated from the main circuits well enough that normal bleeding operations won't push crud through the ABS. However, if you run the master cylinder dry or replace the master cylinder, you must remember to bleed the prime pipe (this is the tube coming off the side of the plastic reservoir) using the bleed screw on the ABS unit.
Old Nov 18, 2020 | 07:19 PM
  #40
aklim's Avatar
aklim
If you pump, I think that when you release the pedal, it might suck air into the system.
