A/C / Heater Help!!!!!
Old Dec 6, 2002 | 01:30 AM
Wheelman's Avatar
Wheelman
Default A/C / Heater Help!!!!!
I just replaced my heater core, and now when I try to use any of the options on the a/c unit (auto, bi-lev, econ,(what does econ do anyway :crazy: ) etc) i can hear the blower motor come on but i cant feel any air coming out of the vents. For some reason the air blows hard out of the defroster, but nothing else. I know my blower motor was weak before, but I used to be able to tell when the blower was working. :mad It is so irritating I can feel the heat but its not coming out of the vents!!! Any ideas on what to look for when I take it back apart again??
Thanks in Advance
Old Dec 6, 2002 | 01:36 AM
Mike's 86's Avatar
Mike's 86
Default Re: A/C / Heater Help!!!!! (Wheelman)
Check for any disconneted vacuum lines around the heater. Mike
Old Dec 6, 2002 | 01:39 AM
Wheelman's Avatar
Wheelman
Default Re: A/C / Heater Help!!!!! (Mike_D)
funny you say that becuase after i fixed it there was a hissing noise that turned out to be a vacuum leak from a small black hose. I hooked it back up and the hissing stopped but i realized the connector i plugged it back into actually had 2 different places to plug a hose into. Do you think this is the problem? Does vacuum actually control where the air from the blower goes??
Old Dec 6, 2002 | 08:56 AM
PTz-92-LT1's Avatar
PTz-92-LT1
You are correct, the vacuum powers the deflection of the doors that control the flow.
Old Dec 7, 2002 | 09:23 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Did you check on putting a higher CFM fan in there...if so I need to find out which one....I want more air to blow....higher capacity....did you find one?????
Let me know...
thanks
tony
:confused:
To A/C / Heater Help!!!!!
