Opti Eliminator kit...
Old Nov 27, 2020 | 09:43 PM
95LT1ZF's Avatar
95LT1ZF
It's cool that someone did all the R&D for something like this, but it sounds sort of like hanging a chandelier in a haunted house.
Old Nov 27, 2020 | 09:46 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
It's a wonder the OEM's didn't slap that on their cars in the '80's and onward. That would have been a fantastic ROI for CAFE and EPA.
Old Nov 27, 2020 | 09:47 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Originally Posted by rhandle
It would be a lot easier to just install an lS3 than figuring out how to modify to accept a distributor shaft
Ahhh....people have already "figured it out". There is a forum member on these very forums that'll do it for you if you can't figure it out on your own. That ain't a limiting factor.
Old Nov 27, 2020 | 10:10 PM
84 4+3's Avatar
84 4+3
Originally Posted by drcook
This is a clarification of why I say I saw a difference.
30 yr old truck with a big pig engine -vs- small more modern design V6
I don't have the paperwork any more, but we have been under emissions testing here since 1996 and was provided with the test results, actually HAD to have the test results to get license plates.(still do). I had a 1997 Buick Skylark with a V6 that ran very nice. According to the sniff test, the truck ran cleaner than the car. The test encompassed putting the vehicle on a dyno type of device so they could test at varying speeds. A 454 with a rudimentary fuel injection ran cleaner than the V6 Buick did AFTER I put the box in. We are on odd and even years, so a 91 and a 97 had to be checked at the same time so I could get my plates on my birthday, that is how Ohio does it.
We are not as bad off as California is though.
Of course, OBDII is a snap, just plug it in, passes or don't and away you go.
A couple miles a gallon was very noticeable.
Did it make x more HP ? Can't say. Did it run better, absolutely. It was burning up more of the fuel, especially the unburnt hydrocarbons. The 454 of 1991 was not as efficient as the 454 of a couple years later. Simply by unplugging the box from its power source changed the feeling of the engine. As I said, the "crispness". It didn't turn it into a race truck, not saying that.
It did get better mileage than the 1989 454 that ran off with my ex-wife. (same gear ratios, both were 4x4 with 3.73:1 differentials) I still had/kept the horses though, kept the place, she went down the road. When you are hauling 10,000 lbs of horses and horse trailer behind you, you can tell if something has helped or not. I pulled the horses all over and hauled lots of hay with that truck, both for myself and others.
This is what we have been living under since 1996 and what I judged by. Very scientific.
https://epa.ohio.gov/dapc/echeck/why...to%20the%20air.
Now I have to ask because a couple things to me don't exactly add up. I can see emissions being cleaned up. But from my limited experience with MSD boxes, they've generally resulted in more fuel burn in my efi vehicles... O2 sensor sees leaner exhaust and adds fuel back in generally. I'm not denying it but wondering if say something else were going on that maybe addressing that in the ignition system would have fixed or ended with the same results or similar...
as far as my experience cleaning up exhaust, on the 67 it made no difference other than my vacuum advance doesn't play as well... so mileage actually dropped in that instance. I always wondered if it had enough spark energy to jump out early when commanded by the ICM... and that caused the issues I had. It would buck like it were over advanced.
Old Nov 27, 2020 | 11:33 PM
Nomake Wan's Avatar
Nomake Wan
Originally Posted by Tom400CFI
You'd have to do the LT1 distributor hole mod to make this work on an LT1, but it's another $1200 option for those who've had enough with their opti's.
oh hi there
https://www.camaroz28.com/forums/lt1...or-lt1-317124/
Old Nov 28, 2020 | 10:17 PM
93Rubie's Avatar
93Rubie
Originally Posted by dizwiz24
im superior bc I can (and have) put an MSD box on my optispark for multiple sparks and a hotter spark.
you cant do that with coil on plugs.
IMHO coil on plugs just cheapened things up for the OEM and is why they did it
Really COP cannot have multiple sparks....that interesting....
I guess EVERY FORD in like the past FOREVER is defective then, because they hit multiple times at idle. ALL of them.
In STOCK trim too.
Your turning into a real troll with that post. COP has SO many advantages it isn't funny.
Old Nov 28, 2020 | 11:02 PM
dizwiz24's Avatar
dizwiz24
In STOCK trim too.
youve never really liked anything ive had to say on here, so why dont you just say that 🤷🏻‍♂️
frankly im tired of explaining why a $69 optispark doesnt work well. Or even a $500 MSD optispark doesnt work well either.
Or explaining how a vent kit fixes problems with the 92-94 design
people wanna re-invent the wheel, have at it
Old Nov 28, 2020 | 11:23 PM
arbee's Avatar
arbee
That is great news. Hopefully that is the end of your nonstop babbling about optisparks and Mitsubishi sensors.
Old Nov 29, 2020 | 08:10 AM
dizwiz24's Avatar
dizwiz24
How else is it explained to the daily newbs that join with questions on it or the misconception that ‘the optispark just sucks under all circumstances’ bc either they (or the PO) put in a cheap optispark that doesnt work.
the mods refuse to make anything on the optispark a sticky
Old Nov 29, 2020 | 08:59 AM
arbee's Avatar
arbee
Damn! And we were so hopefull. You said you were sick of explaining it and here you go some more. There is plenty of information now in the archives without you going on and on about the opti.
Old Nov 29, 2020 | 11:59 AM
Red86Z51's Avatar
Red86Z51
Finalist 2020 C4 of the Year - Unmodified
C4 of Year Finalist (stock) 2019
If Diz's posts bother you so much (and by your posts they certainly seem to), why not just move on and pass on reading anything he puts out there? Live and let live man...
Now, what say we get back on topic.
Old Nov 29, 2020 | 12:24 PM
84 4+3's Avatar
84 4+3
There's actually a few posters in here that bother me. All for different reasons. I don't block or ignore anyone simply because its funny watching people make themselves look foolish. Honestly everyone in this thread has done it at one point or another, I'm especially guilty.
Old Nov 29, 2020 | 12:25 PM
  #33
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
II think it's bothersome b/c it's misinformation. At LEAST bordering on it. Diz repeatedly states that Opti's are better than anything that's come since....that ain't true. He starts threads asking if anyone could or has adopted Opti to and LS engine. It's absurd and at best, a waste of postings. At worst, the unwitting might be confused by it.
I like Diz...but the opti thing is ridiculous. I "get it", w/his perspective that opti's also aren't the worst thing ever/total junk/fill-in-the-blank with what people say about opti's. I feel that they're (good ones) are pretty darn reliable -at least as good as GM said they would be, and they're definitely not that hard to change if they do have a problem. Worth changing them out? I'm with Diz, here and say "no", not worth spending $1200+ to change to something else, which is why I still have an opti. BUT others feel differently, so I posted when I saw this MSD system...just one more option for folks.
Old Nov 29, 2020 | 01:45 PM
  #34
arbee's Avatar
arbee
My point totally. Misinformation does nothing for anyone. Differences of opinion are one thing but to ignore technology and dig your heels in because "you stand by what you say" is ludicrous. Optis are what they were for the time. If not for better technology, then why did they abandon it? Diz claims to be an engineer. His entire profession is built around advanced technology. Should we still be using adobe to build our houses? **** and tube wiring? Maybe hall in some wood for the furnace. As mentioned, to post if the opti is adaptable to the LS series just begs for comments such as mine - or, "What has to be done for the C4 to beat the C8? That's like asking what has to be done to a Spitfire to out-dogfight an F18!
Old Feb 28, 2024 | 04:38 PM
  #35
Pitdog's Avatar
Pitdog
2nd Gear
If you don't mind me asking what is the LT1 distributor hole mod? We are talking about OPTI spark delete right? I really really would like to get my car running by summer but I refuse to waste any more money by putting another opti spark in my 1992 corvette.I have put in the vented one like on the 1994-96 models and that has gotten me oh about 4 month / 800 miles. That was last year, the car currently has 78,000 mile on it. Torq Head support told me that they don't make a kit to fit the 1992 & 1993 corvette for LS conversion because of the OEM wiring on the corvette is vastly different in the 92-93 & 94-96 corvettes in addition Torq Head said it didn't plan on making one. So if anyone can help point me in the direction of somebody that sell a reliable opti-spark deletion kit for a 1992 & 1993 LT1 I would for be ever grateful.
