Automatic trans question
Old Nov 29, 2020 | 11:48 AM
Jossey's Avatar
Jossey
6th Gear
Default Automatic trans question
I posted before that I bought a c4 that the previous owner started to do a manual swap but sold me the car stripped. I decided to leave it automatic cause the the 700r4 was still hooked up. I changed the inside wi
ring harness to the automatic.( kept the manual harness for a future build) or if anyone is interested) my question is do I have to change the engine harness too, I know I have to change the ecm which I have for an automatic I just want to know if I have to change the whole harness anyway all comments are welcomed thank you.
Old Nov 30, 2020 | 01:17 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I don't know about the harness but for the ECM you only need change the EPROM.
Don't forget the kick-down cable from A4 to TB.
You will benefit from getting a FSM for whatever year you are working on.
Old Nov 30, 2020 | 02:11 PM
84 4+3's Avatar
84 4+3
I believe engine side is identical. You just need trans side and the mentioned kick down cable. I don't recall any extra parts other than that.
Old Dec 1, 2020 | 01:55 AM
stew86MCSS396's Avatar
stew86MCSS396
From: Liliha Bakery stuffing my face with coco puffs!
Me thinks you should look at the BCC on the MEMCAL and cross it to this spreadsheet to see if you still have an AUTO bin. P/N switch probably part of shifter wiring but does go to ECM???
BCC Lookup
Old Dec 1, 2020 | 03:44 PM
Jossey's Avatar
Jossey
6th Gear
Thank you so much can't wait to start my vette.
To Automatic trans question
