ECU Chip Removal
Old Dec 6, 2020 | 05:54 PM
RossGN's Avatar
RossGN
Default ECU Chip Removal
What is the safest method to remove the chip. I've changed chips on Grand Nationals before, but can't get this one to budge by hand. Don't want to damage the chip or ECU.
Old Dec 6, 2020 | 06:17 PM
Benny42's Avatar
Benny42
If you press the blue tab and the white tab on the ends of the adapter, it should eject the whole thing like a cassette tape. The chip itself may be soldered to the adapter board and not be removable alone.
Old Dec 6, 2020 | 07:10 PM
RossGN's Avatar
RossGN
Got it...thanks
Old Dec 6, 2020 | 07:44 PM
Nomake Wan's Avatar
Nomake Wan
Going by the photo, that's an aftermarket adapter, and should eject as stated above. However the chip appears to be in a socket and not soldered to the adapter, so it should be easily removable so you can read it, make changes, burn a new chip, etc.
Old Dec 10, 2020 | 11:14 AM
jazfe's Avatar
jazfe
Looks like an aftermarket board. I had one that could not be removed unless the whole computer box was taken apart.
To ECU Chip Removal
