guage temp sensor
Old Dec 8, 2020 | 09:43 AM
1990frankp's Avatar
1990frankp
Default guage temp sensor
hello- bought a 1990 c4 in june from the 81 yr. old original owner w/ 39500 miles.
runs just fine but temp guage only goes to about 110*. i cleaned the 'button type' connecter but no change.
the sensor has been in the aluminum head for 30 years and am wondering i if i remove it the threads in the head will get destroyed due to the bi-metal corrosion effect ?
i did get a new 'button head' sensor from jegs.
i do have temp gun and shows it;s running 185 -190 at the thermostat housing.
Old Dec 8, 2020 | 10:48 AM
WVZR-1's Avatar
WVZR-1
What happens at the gauge if you ground the DK GRN (I believe correct) wire?
Old Dec 8, 2020 | 01:17 PM
1990frankp's Avatar
1990frankp
pegs hot but has anyone had an issue removing a 30 year old sensor from an aluminum head ?
Old Dec 8, 2020 | 01:21 PM
WVZR-1's Avatar
WVZR-1
That's what a person would expect and I can't offer any '1st hand experience' with an issue removing it so you're still looking!! Brass & aluminum you're most often told to expect issues. I'd think there are many who've been where you're at! I ain't.
Old Dec 8, 2020 | 02:31 PM
auburn2's Avatar
auburn2
FWIW the one on my 89 came out fine a couple years ago.
Old Dec 8, 2020 | 06:39 PM
1990frankp's Avatar
1990frankp
thanks for the rep[y ,was the head cold or warm /
Old Dec 8, 2020 | 06:59 PM
ctmccloskey's Avatar
ctmccloskey
Welcome to the Corvette Forum 1990frankp!
If you are not sure try a "Bit of Heat" using a Hot Air Gun along with some good penetrating oil like "KROIL Oil." If you heat it up and spray it with penetrating oil a couple of three cycles virtually anything will break loose. Heat and oil work the best together. By heating the part first and then spraying it with oil the oil will be drawn into the joint or threads.
I use a Torch for heat when I feel secure and comfortable that I won't damage anything. I always get a Fire Extinguisher and have it handy when heating with a torch. The one on my 1988 came out with out any problems. The sensor housing was Brass and not Copper. Copper is what is incompatible with Aluminum. Brass is not an issue with your aluminum heads.
To guage temp sensor
