Ball joints
Old Dec 11, 2020 | 05:50 PM
Hawkeye56's Avatar
Hawkeye56
Default Ball joints
I am going to change all of my ball joints and wanted to see what brand you all have had good luck with. I was considering Moog but visiting with a NAPA shop they said they had a lot of warranty problems. Not sure to believe that. So please help me decide what to order.
Thanks Hawkeye56
Old Dec 11, 2020 | 08:39 PM
grandspt's Avatar
grandspt
Thanks Hawkeye56
I have used the Moog ball joints in my GrandSport and have had good luck with them. I changed my lower ball joints about ten years ago and I used Moog.
When I installed the Ridetech Coil over setup this year I replaced both upper and lower ball joints at the same time.
My lower ball joints still looked brand new but I changed them anyway. So I trust the Moog brand. I have been using Marine grease in them but I don't think that should matter much.
I'll add that the upper ball joints are a pain to remove and I had the control arms removed from the car.
The stock upper ball joint needs to have the rivet heads removed and then the remaining part of the pin has to be driven out carefully as to not a damage the control arm. The upper joints are by far the most time consuming to change out.
The lower ball joints are easy to change out with a press.
Old Dec 11, 2020 | 08:54 PM
Hawkeye56's Avatar
Hawkeye56
I had always heard Moog was quality products.
I imagine the Napa was just trying to sell his product. I have found Summit to have the best price.
Thanks Hawkeye56
Old Dec 11, 2020 | 09:34 PM
grandspt's Avatar
grandspt
I believe I purchased mine from Rock Auto.
Summit is good too, not sure what I paid.
Old Dec 11, 2020 | 09:55 PM
Hawkeye56's Avatar
Hawkeye56
Thanks for all the advice.
Thanks Hawkeye56
To Ball joints
