Venting on my install (Shifter)
Old Dec 7, 2002 | 01:23 AM
MongooseLT4's Avatar
MongooseLT4
Default Venting on my install (Shifter)
Well I got a B&M Shifter and decided to install it tonight. Things started off well the console came off and the stock shifter seemed to be ready to come out. I got the car up on the lift to pop out the pin holding it to the gear shifter and...... To make a long story short it was the biggest PITA ever!! The idea is pretty strait forward but when it comes down to actually doing the job it is not at all easy.
Finally got the car back together minus the Exhuast (broke a bolt). THe B&M is really really really short and very notchy I drove around the block a few times and I really like it alot hoever the loud exhuast is making it not so fun I'm going to get it fixed tomarrow. I should be just what I want but it is going to take some getting use to. I'll have pics up soon :cheers:
Oh yeah I also found a nail in one of the rear tires :cuss
Old Dec 7, 2002 | 01:25 AM
bogus's Avatar
bogus
Default Re: Venting on my install (MongooseLT4)
shifters are easier to install when doing a clutch...
I had mine done that way - Hurst, tho.
Glad you like it!!! thats the important part!!!!!
Old Dec 7, 2002 | 03:14 AM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
Default Re: Venting on my install (bogus)
Best way to do it. ine will be done with the tranny out. Hurst as well.
Old Dec 7, 2002 | 03:21 AM
STL94LT1's Avatar
STL94LT1
Once you start driving the car again, you will forget all about the pain of the install.
Old Dec 7, 2002 | 09:01 AM
Nathan Plemons's Avatar
Nathan Plemons
Hey, could be worse. I actually managed to get mine installed without removing the exhaust being that all the bolts on the exhaust were siezed completely. Only took about 2 hours, a lot of bleeding and profanity but it was well worth it.
If I had to do it again though I would do it with the tranny out when I replaced the clutch.
In any case you'll love that B&M so much that you'll forget about the install troubles. Good choice :cheers:
Old Dec 8, 2002 | 12:52 AM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Did you install the shift kit????
:cool:
Old Dec 8, 2002 | 02:37 AM
STL94LT1's Avatar
STL94LT1
Default Re: Venting on my install (oldace84)
:cool:
There is no shift kit for a manual. He installed a B&M shifter.
Old Dec 8, 2002 | 05:02 PM
VETTENV's Avatar
VETTENV
Cruise-In V Veteran
Cruise-In VI Veteran
Don't think I'd ever do it again without the tranny out! Wait till you do a tune-up...now that is fun! :jester
Old Dec 8, 2002 | 05:48 PM
maduraj's Avatar
maduraj
Default Re: Venting on my install (Jeffvette)
I replaced the factory shifter with the B&M with the tranny in the car and it was a pain. Now I have the tranny out of the car, so I replace the B&M with a Hurst. This was a lot easier to do now.
To Venting on my install (Shifter)
