Spring Z51?
Old Dec 7, 2002 | 02:05 AM
MongooseLT4's Avatar
MongooseLT4
Default Spring Z51?
is their any differance between the stock springs and the z51 springs? IF so whencan I buy a fron spring for a Z51 car? Thanks
Old Dec 7, 2002 | 08:39 AM
96LT1's Avatar
96LT1
Default Re: Spring Z51? (MongooseLT4)
The FE1 base suspension base spring rates are 60 and 26 N/mm for the front and rear. The Z51 spring rates are 73.2 and 33 N/mm front & rear. These are for the 96 GS coupe. The spring rates are different for the convertible. I'm getting these rates from Hib Halverson's C4 suspension chart... http://vettenet.org/susp_chart.html
These numbers convert to:
343 Ft lbs/in & 148 Ft lbs/in (Base FE1)
418 Ft lbs/in & 188 Ft lbs/in (Z51GS)
Ft lbs/in = Foot lbs per inch
I would try to get them from Jeff Kopp (18carfan) first. If he can't get them, try Vette Brakes and Products but make sure you specify the springs rates you want. (DON'T let them talk you into their "standard" recommended set)
Old Dec 7, 2002 | 11:19 AM
silver & red CE's Avatar
silver & red CE
Call up a Vette recycler like Vette2Vette and purchase a set of 92-early95 FE1 springs (front and rear), the rear is slightly stiffer than the 96 Z51, the front is the same as the 96 Z51. Then call Jeff or Dal and order a set of 92-95 Z07 swaybars. For shocks you have a couple of options, some stiffer Bilsteins, rebuild the ones you have or go with some HALs. You'll be amazed at how much better the ride is with almost no increase in harshness.
Eric
Old Dec 8, 2002 | 12:02 AM
MongooseLT4
Default Re: Spring Z51? (silver & red CE)
I just need the front 96' Z51 spring....Mine is cracked :eek:
Old Dec 8, 2002 | 10:47 AM
silver & red CE
Since you're adding improvements, I just assumed you were looking to make your Vette handle better too. Two options: purchase a new one for ~$360 discounted, over $500 list, or call a Vette recycler and purchase a used 92-early 95 front spring, it's the same as the 96 Z51. I saw a big stack of springs at Vette2Vette.
Eric
To Spring Z51?
