Replacing water pump and thermostat. Have seen discussion on sealant/no sealant with much advice not to use sealant on today's gaskets. OK. But I do want to make sure the new t-stat gasket adheres in position when I put it on. I've read no RTV sealant and then others say RTV sealant. I've also seen advice that, if the part comes with gaskets, that means you don't need sealant. OK, the water pump did come with gaskets but I'm still concerned the t-stat gasket not move as I attach the housing. So my thought is a little thin coat of sealant (or something else?) to make it adhere to the housing as I put it on. Yes? No?
I wouldn't, b/c it makes the job a PITA, the next time. Many new T-stat gaskets come w/adhesive on one side already. Put the stat in, slap the gasket to the intake, sticky side down...put the housing on. Done.
Thank you all for the responses. Either the aviation or hi-tack will do. I'd like to go dry but I really need to hold the gasket in place as I apply. Thanks again.
They make these gaskets that have adhesive on them. Like a sticker. They work good.
I like Indian Head on paper gaskets. It's old school but I've never had a leak while using it and it removes easy. (Unlike rtv... had a few attempts at some T-Stat gaskets on a poncho before I went back to good old Indian head with no issue the RTV kept dripping for some reason...)
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
You can do some searching and find these "Thermostat Gasket - Molded Rubber on Aluminum Carrier" a little cheaper if cost is a concern. They do work great and I will "never" (lol) go back to a paper type gasket for this. I had an issue with mine that no matter what material I was using after a while they would start to seep/soak through and eventually **** me off. I even tried Kevlar gaskets, no go. I came across the gaskets mentioned above and said..."what the hell" nothing else seems to work. I was skeptical at first, but they really work great IMO and ordered a few extras just in case. Another one is the O-ring type with swivel neck that a friend swears by, but it is pretty much the same principal.
The one I use is a soft plastic with a retained O-ring. Works well.
