Thinking about carbing a 1989 L98. Engine will be going into a 79 Impala.
I know I could make more power with the carb but this would be up high revs as the L98 TPI intake makes torq down low. Will I loose lb-ft down low, if so, how much?
Would luv to see a dyno sheet from an otherwise "stock" L98 with any intake (preferably EB Perf or Sum Stage 1) and Q-jet.
The Eddy Performer intake produces good low rpm torque so doubt you would lose any low end torque with it and a qjet carb. L98 cam is pretty mild so if you are going carb I would go with a bigger cam since you will not have to worry about computer controls anymore and still have good low end torque.
I know the swap to only carb without cam or other internals is probably not worth dyno´ing in some people´s eyes. :-)
Anyways, would be great if somebody would have a dyno sheet. I have searched the web but came up with nothing.
There are many dyno tests on 350 smallblocks on the internet and many were done by Westech Performance. I recall a test on a 9.7 c r 350 comparing the L79 cam with the little comp 252 cam with 206 206 @ 050 430 lift 110 lsa. The 252 cam made 349hp at 5100 and 388 tq @ 3900 and the l79 cam 222 222 @050 114 LSA made 350 hp @ 5400 and 380 tq @ 4100 rpm. Many more tests on the internet so start searching! I ran the comp 252 in a stock 305 sbc in my wife's 87 formula firebird and was a great little cam.
Not a stock comparison but Richard holdner did a comparison on a worked motor. But the curves will still follow the same pattern... it lost 40 numbers in torque from around 3000-4000 but bottom bottom was similar. It improved the top end where it flattens out normally at 4500 though. Should behave in a similar manner... dual plane with a carb is a solid all around intake imo.
I was looking for a dyno sheet of a carbed L98 specifically, not just some built 350.
Did you ever dyno the 252 in the 305?
No dyno tests, just my butt dyno. Your L98 is nothing special it's just a 350 so do some research on carbed 350 dyno tests and forget about finding carbed L98 dyno tests!
Actually, the L98 makes "tq" right in the mid range; from about 2800 or so, to about 3500 or so. That is what we call, "Mid range". Down low, which is what I'd call idle to ~2000 or so? It makes about the same as most any other ~350 CID NA V8.
All you're doing with the different intake is getting rid of the mid range "bump" in torque that the TPI creates.
Well, the improvement of the L98 over the SB seems to start at 2,000 rpm, as to the below chart.
I hoped the L98 with better flowing heads and 9.5:1 CR would do better - significantly better - than your regular 8,5:1 CR 190hp 350 with stock iron smog heads. Actually, even better than a cammed 350.
Here is the comparison of a stock L98 (TPI still) to a cammed 350 Targetmaster of a friend of mine:
I am mostly interested in the L98, because tq and hp are generated at lower rpms. I don´r race and I don´t cruise at 5,000 rpm. To move the Impala, torq at lower rpm is what I am looking for.
You may right, tho, that this "bump" will be lost with swapping the intake, as the long TPI runners are said to be the reason for improved figures.
Your impala is fairly heavy with a 2.41 rear gear most likely so may be a gear change would be better to boost your low end power.
The TPI runner length is entirely responsible for the tq "bump" in the area around 3200 RPM.....and also entirely responsible for the nose dive above 4500.
Krusty, I belive both engines have been worked on, but thank you for the sheet as a mere curve course comparison.
Wilcar, yes gears, but they will up the highways revs. I was thinking about a TH700 for better power in 1st and lower revs in 4th. The 700 is 3.06 in 1st, IIRC.
Agree that a 700r4 would be a good move for you with that bad azz 1st gear!
