1990 manual difficulty shifting
Old Dec 27, 2020 | 12:01 PM
1990vetteconvert's Avatar
1990vetteconvert
Default 1990 manual difficulty shifting
ran the vette today, 32 degrees here in PA, first time in a month. Really hard shifting gears. Shifts gears fine when engine is not running. Thoughts?
Old Dec 27, 2020 | 12:34 PM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
i honestly cannot help in terms of 'cold weather' zf6 operation but i do know that amsoil syncromesh manual transmission fluid is the ultimate that i have found for these trannies. perhaps you have an oldschool fluid that is too thick in the cold. try full synthetic?
Old Dec 27, 2020 | 12:41 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Didi you run it long enough to heat it (the trans) up? And did it still shift with difficulty?
Old Dec 27, 2020 | 12:43 PM
1990vetteconvert
thanks, still difficult shifting even after warmed up. Have to check clutch and slave cylinder fluid levels.
Old Dec 27, 2020 | 01:10 PM
cv67's Avatar
cv67
St. Jude Donor '05
Problem that suddenly happened? Guess if the hydraulics are good must be as the others said..thick and cold
my T56 is sensitve to this also.
Id call Bill at ZFDoc if anyone knows he will. Id be afraid most local tranny shops are going to want you to bring it to them....and sell you something.
Old Dec 27, 2020 | 01:26 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Two things could have happened:
1. Your slave could be leaking slowly. Car sat....you lost some fluid, now it's too low.
2. fluid was low, got cold....contracted and now it's too low.
Old Dec 27, 2020 | 03:08 PM
1990vetteconvert
clutch master cylinder reservoir was way down. Topped it off and problem went away. Will check the slave cylinder for leaks next week when I have time. Thanks all.
Old Dec 27, 2020 | 07:22 PM
corvette95's Avatar
corvette95
90% of all ZF6 transmission failures are the result of weak hydraulics..... replace your clutch master and slave and cable now if you haven't already and save $4500 for a transmission rebuild. Also be sure to use the correct fluid. Also change your transmission fluid... see zfdoc.com website,
Old Dec 27, 2020 | 07:35 PM
1990vetteconvert
thanks everyone, great input
Old Jan 24, 2021 | 04:07 PM
C4ProjectCar's Avatar
C4ProjectCar
Are ZF6 rebuilds really $4500?? Time to start looking into a T56 swap...
Old Jan 24, 2021 | 04:54 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
I think most would just buy another used one. I would...before spending $4500.
Old Jan 24, 2021 | 04:59 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Had similar issue with my "new" '89 ZF6.
The master would gradually drop in level with hard shifting eventually resulting.
Since the master was not leaking, a new slave solved the problem.
Old Jan 24, 2021 | 06:25 PM
C4ProjectCar
Yeah, I was counting on it being about $3k including shipping both ways. For $4500 I'd definitely either buy a used one with reasonable mileage or swap a T56. I like the ZF6 and the idea of keeping my car somewhat stock, but you can buy a brand new T56 Magnum for about $3k (of course a trans swap has other associated costs, but still). I think I'll call ZFDoc tomorrow to get a quote.
To 1990 manual difficulty shifting
