Steering shake when Slowing down from 80 MPh
Old Dec 8, 2002 | 02:29 PM
YellowC4's Avatar
YellowC4
Default Steering shake when Slowing down from 80 MPh
hi My steering wheel Shakes when Accelarting fast from 55 to 80 or slowing down form 80 and it doesn't do it all the time I checked the hubs for play and there good I balanced and aligned the tires and it still does it any Ideas :confused:
Thanks :flag
Old Dec 8, 2002 | 02:35 PM
TA's Avatar
TA
Default Re: Steering shake when Slowing down from 80 MPh (YellowC4)
Might want to double check the balance of the wheels.
I know you said you just did them, but its possible you threw a wheel weight.
Old Dec 8, 2002 | 06:24 PM
gbody5's Avatar
gbody5
Default Re: Steering shake when Slowing down from 80 MPh (TA)
How long since a brake job? Rotor wear can also cause vibration, usually noticeable all the time (esp when on the brakes), but is possible to only show up at higher speeds if they are only slightly worn.
Old Dec 8, 2002 | 06:58 PM
YellowC4's Avatar
YellowC4
Default Re: Steering shake when Slowing down from 80 MPh (gbody5)
I put NEW Drilled rotors with pads about a month ago it only shake Between 60 - 80 mostly at 70 MPH. I checked Everything in the front end and it looks good one more thing could a out of balance dirve shaft cause the steering wheel to shake
Thanks for thr reply everybody :flag
Old Dec 8, 2002 | 07:13 PM
Wadoka's Avatar
Wadoka
St. Jude Donor '03-'04
Cruise-In 1-2-3-4-5 Veteran
Retorque your lug nuts. Probably won't help, but it's worth checking.
Also check the air pressure in all four tires.
Old Dec 8, 2002 | 09:09 PM
JCAIRE2's Avatar
JCAIRE2
Default Re: Steering shake when Slowing down from 80 MPh (Matt Black)
I have the same shimmy at ~70. Actually, mine comes on at 73mph according to the speedo, and goes away at 76-78mph. I haven't been able to figure it out either. So, I just drive slower than 73, or faster than 78. Best I can tell, it's somekind of harmonic vibration, but really doesn't have a specific cause. My tires have been balanced twice, driveshaft balanced, etc... and nothing I have done will make it go away.
J
Old Dec 8, 2002 | 10:16 PM
mash557's Avatar
mash557
Had the same sort of thing with mine. Took it to local Discount Tire and happened to get someone who took a little pride in what they did and low and behold he found an out of round tire. He replaced the tire and spent some time getting the tire just right so it didn't need much weight. Car was smooth as silk after that. Tires had been balanced 3 or 4 tire before that with always the shaking. Good Luck, there is an answer to this.
To Steering shake when Slowing down from 80 MPh
