Has anyone reverse-engineered ECM-CCM comms?
Sort of. In that you only have a single communication channel and if multiple devices try to talk at once the message is lost, yes. In that there's a clear way to demand a direction, no.
Also, didn't they ditch the +12v ALDL pin around the time they switched to 8192? I thought I read that.
As the +12V is a requirement of the OBD2 standard, the 94-96 Corvette ALDL connector has +12V on pin 16. For the earlier CCM cars (pre-94), you are correct that there is no +12V pin (though there is a fuel pump +V connector on pin G).
It's for a device that reads both 160 baud and 8192 baud, but I think I can just pick whichever one I need (90% sure I need 8192). For 8192, the diagram shows the serial line connected to TX and RX in parallel, which I've read is necessary due to the fact the ALDL is half duplex. There's a 1k resistor on the RX pin and a diode on the TX pin for some reason? As expected, the vehicle ground goes to the board's ground.
Here's a GitHub project to read 8192 ALDL with an Arduino. It's for the 1227165 ECM though, which is before the CCM was added (1227727 ECM). This certainly means that it will not decode the datastream properly, but I wonder if the wiring description holds:
I'd want to skip step 4 for sure, and I don't see why I'd need to connect pin 4. Otherwise this basically describes the wiring above.
For the '94-'95 guys, here's a schematic from a now-defunct webpage (thanks Wayback Machine).
Do you have any source I could look at explaining the difference between "early" and "late" 8192? Repeating "160 baud is irrelevant" is not helping me - what would help is knowing why it is irrelevant, and which aspects are different between a 160 baud system operating in 8192 mode and a newer 8192 system. Nothing I read even acknowledges that there's a difference between the two, and a lot of things just say "this is for GM 8192 baud". Without understanding the difference between the two, I can't filter out irrelevant information.
I know much of my research is beyond the scope of what I'm trying to do here, but A) I can't afford to risk damaging something and B) if I ultimately make an interface box, I will need more functionality than a passive sniffer.
That's bizarre that your logic analyzer works with just one lead connected. That totally defies my knowledge of circuits; I'd be really interested if someone knows how that works. Not to get too off topic.
Edit: New roadblock. The Uno only has one UART, which means its RX and TX pins are one and the same as the RX and TX on its USB port. If I hooked this up as planned, it would be the same as just connecting my laptop's USB port directly to the ALDL serial line. I think I can read serial data over digital pins though.
I'll post the sketch and data in a bit.
Edit: Collapsed some of my rumination. However, there's a little worthwhile info in here.
- What's the minimum message length? Would it be four bytes? [Device ID] [message length] [mode] [checksum]
- Do $8D ALDL messages all have a checksum? Edit: Yes, it appears they do. However, I see some three-byte messages that have no mode byte.
- Why is it necessary to silence everything to read the diagnostic datastream? If each message is prefixed by a device ID, couldn't you just filter out the stuff you don't need? Or is the issue that the other devices on the bus are trying to talk over the DDS?
- F0: "CCM ALDL device presence check"?
- F1: CCM
- F4: ECM
- 10: Broadcast?
- 40: ?
- 41: ?
As far as I can tell, the datastream consists of four repeated messages. The values shown were with the engine off.
$41 61 00 EE 00 39 38 01 00 00 00 B4 00 01 49 (when I started the engine, only the first two bytes remained the same)
$40 55 6B (this was constant)
$F0 56 F1 C9 (this was constant)
The question is - what are devices $40 and $41? At first I assumed they were not the ECM or CCM, but now I doubt that. There isn't a single message from $F1. Maybe I have that ID wrong. Didn't @Nomake Wan say the CCM is the traffic cop of the serial bus? If that's the case, its ID must not be $F1.
I found a page talking about ALDL on a car with a BCM. I'm not sure how relevant it is, but it contains the following list (originally from Moates I think?):
THESE MESSAGES ARE TO BE COMMANDED WITH A MODE 7 COMMAND.
COMMAND ID LISTEN ID MES LENGTH
$10 $10 1 HVAC PROGRAMMER MESSAGE
$20 $21 x IP MESSAGES
$22 $22 x
$30 $31 x ECCP/CRT MESSAGE
$40 $41 x ECM MESSAGE
COMMAND ID: THIS IS THE ID OF THE NORMAL MODE MESSAGE TO BE COMMANDED BY A MODE 7 TO THE MASTER.
LISTEN ID : WHEN THE MODE 7 IS SENT TO THE MASTER, THE MASTER TRANSMITS THE REQUESTED NORMAL MODE MESSAGE WHICH MAY OR MAY NOT CAUSE A
RESPONSE MESSAGE TO BE GENERATED BY ANOTHER MODULE. IN ORDER TO MAINTAIN PROPER SYNCHRONIZATION WITH TRAFFIC ON THE DATA LINK, THE
LISTEN ID SHOULD BE THAT OF THE RESPONSE MESSAGE IF ONE IS GENERATED OR THE COMMAND ID IF NO RESPONSE IS GENERATED BY THE
NORMAL MODE MESSAGE.
MES LENGTH: IF THE RESPONSE MESSAGE ID IS THE SAME AS THE COMMANDED MESSAGE ID THE MESSAGE LENGTH IS USED TO DIFFERENTIATE THE RESPONSE MESSAGE FROM THE TRANSMIT MESSAGE.
The datastream definition says that $10 is some sort of broadcast, so perhaps $40 is the CCM requesting an update, and $10 is the ECM responding?
My bluetooth ALDL adapter works for both as well.
- F1: CCM
- F4: ECM
- 10: Broadcast?
- 40: ?
- 41: ?
Before I started the engine, it looks like it was repeating four messages.
40 55 6B
F0 56 F1 C9
The question is - what are devices $40 and $41? I don't recall what else is on this bus. I think FX3 suspension, brakes, and possibly climate control and/or the radio? I guess I don't need to know right now, since they're not the CCM or ECM.
Now to figure out how the ECM and CCM communicate. I'll start by filtering out all the $40 and $41 messages, because I do not think they're relevant. Actually, it might be useful to leave them in so that I can see which message is in response to which. I guess I need to look for back-to-back comms by the ECM and CCM.
Nope. There isn't a single message from $F1. Maybe I have that ID wrong. Didn't @Nomake Wan say the CCM is the traffic cop of the serial bus? If that's the case, I would expect constant messages from it.
I previously understood that the ID byte indicated which device the message was for. Now I'm not so sure. I need to read up.
2. The minimum message length is exactly what you thought--four bytes. Specifically, a message like "F9 56 00 [checksum]," which is a Mode 0 "return to normal" request for the ABS. As defined in the datastream definitions.
3. All messages have a checksum. If you are missing mode bytes, I would suspect your analyzer having a bug or missing a message byte. It's a noisy bus!
4. It's necessary to silence the bus before getting diagnostics because the ECM/PCM is not the bus master. So to request that the ECM/PCM send you diagnostic data (Mode 1 request), you first need to tell the CCM to shut the hell up (mode 8) in order to become the new bus master and issue a Mode 1 request to the ECM/PCM. Same with getting diagnostic data from the ABS computer or any other slave device on the bus.
5. According to my FSM for 1994, the devices on the 8192 baud serial data line are the CCM (bus master), ECM/PCM, ABS/ASR, C68 Climate Control (if equipped), and airbag module. The PKE module, radio module, and FX3 modules are on separate pins (for 94-96, that's pin 8, pin 14, and pin 3, respectively).
6. The CCM is indeed the "traffic cop" of the bus. It is the bus master. All serial data communication flows between the CCM and the other modules on the bus. This is also why the 'paperclip' method works; you're essentially flipping a switch in the CCM that says, "Hey, go ahead and tell the other devices to do a mode 1 fault code report. Then I'll process them and put them up on the dash. And if the user wants to reset a code on a module I'll send that module a Mode 10." The CCM is, quite literally, acting like a Tech 2 when in diagnostic mode.
7. Much like 160 baud, the BCM stuff is completely and utterly irrelevant to a Corvette. Ignore it.
8. The ID byte tells you which device the message relates to. It doesn't indicate the sender or recipient. For example, when the CCM is in diagnostic mode and you request codes for the ABS module, the CCM will send a Mode 1 request with the F9 ID byte. The ABS module will then respond with the requested data also with the F9 ID byte. This is another reason why you have to tell the CCM to shut the hell up if you want to command other modules yourself; because otherwise the CCM will talk over you.
Edit: Here is the only info I can find on "40 55 6B":
Isn't Mode 1 the entire diagnostic datastream? Or does the F9 ID + the Mode 1 cause the ABS to release its DDS, whereas the ECM would need Mode 1 + a different ID?
I'm going to attempt to decode $10 59 08 39 00 00 56.
0x10 and 0x59 are ID and length obviously.
A111 says the next byte is the status word. 0x08 is 00001000, so all bits are zero except bit 4. That indicates that the dash is set to English units, the engine is an L98, and the AC clutch is off. The remaining five bits are "spare". Curious that one of the spare bits would be set to one.
After that comes coolant temp. "Deg C = N*.75 - 40," so 0x39 = 57, and 57*.75 - 40 = 2.75 °C. That's 36 °F, which is spot on. Just for fun, it was 0x49 at the end of my serial log. That's 15 °C = 59 °F. Seems reasonable.
Next is engine RPM. "RPM = N*25." My engine wasn't running, so 0 RPM is correct. The end of the log showed 0x25, which is 925 RPM. Perfect.
Then vehicle speed. "MPH = N." Can't really test this one without moving, but it was 0 throughout the log.
Last, the checksum.
The definition file also shows $F0 56 F1 as "CCM ALDL DEVICE PRESENCE CHECK." Possibly something to interact with a Tech 2? Or maybe it's something obvious.
That's a nice sanity check.
That leaves just two lines to be decoded.
$40 55 6B
You are correct that the F9 [Mode 1] specifically tells the ABS to send a diagnostic datastream in response. And that if you wanted a diagnostic datastream from the ECM, you'd need F4 [Mode 1] instead. But also that you must be the bus master in order to send those requests because otherwise the CCM will talk over you.
It looks like the CCM has two serial data lines, but they tie together. I'm thinking these must be RX and TX, and they combine because it's a half-duplex system. The serial bus connects to:
- ALDL connector pin M
- Heater and A/C programmer - electronic AC only (C68)
- C68 has the ability to display engine parameters, such as RPM or CTS. I wonder what this communication looks like? Perhaps logging it would shed some light on things. It occurred to me that this is one more functionality that a standalone would lose. I'm not worried because it's so hidden, and a standalone provides much nicer datalogging, but just a note.
- Electronic brake control module
- Interestingly, this one only shows one pin, whereas everything else displays both RX and TX. Perhaps RX and TX tie together internally? As I understand it, everything on the bus needs both since the CCM coordinates everything.
- Electronic control module
It does not appear selective ride control (FX3) communicates with the CCM. The SRC computer directly controls the "service ride control" light. It shares the VSS input to the ECM.
I can't find a connection between the radio and the CCM either. It gets VSS directly just like SRC. Curiously, the radio control head, heater and A/C control head, and heater and A/C programmer head all are connected to ALDL pin J via the "entertainment and comfort data line". Without C68, it's just the radio on that line.
Edit:
Injector flowrate:
Progress!!! I was thinking about what the ECM must be sending the CCM, per my edit to my previous post, and I realized that if it's sending the components rather than the calculated value it must be sending the CCM the injector flowrate. I looked in my bin, and I have it set to 5.63 gal/hr. The raw value corresponding to that is 0xB4. I looked in the datastream, and the 11th byte (starting at zero - think this is convention) is 0xB4 in every single entry. I can test this hypothesis by tweaking my bin and taking another log.
Assuming the preceding is true, it must also be sending engine speed, injector PW, and VSS. Or, perhaps it's sending RPM, running total fuel, and running total distance. It's also possible the ECM might be combining one or more of those three things, but if that's the case I'm not sure why injector flowrate wouldn't be added in as well.
Here are lines from the beginning, middle, and end of a log.
Engine speed:
We know this is sent in the $10 line, but I'm not sure if the CCM can/does combine data from two different messages. At any rate, I think byte 2 of the $41 message is RPM. It stays close to 0x25, fluctuating slightly between 0x24 and 0x26.
Injector PW:
I looked in my ADX, and injector BPW is calculated in ms as "X * 0.015259". Looking at a recent datalog, injector BPW is around 2ms at idle. Dividing by 0.015259 gives 131 decimal = 0x83. Okay, I don't see any bytes that remain around this value. So maybe not.
Running total fuel:
It looks like that ticked up about once per second at idle. I'm not sure I even have a second of data (Arduino serial monitor overflowed very quickly), but I could see if I can find something that was zero before I started the engine and both 1) nonzero and 2) monotonically increasing after.
Byte 2 passes the first check but not the second.
Byte 4 is zero in both cases.
Byte 8 passes both checks, but it's increasing much faster than it should be.
Byte 9 passes both checks, but its growth is far too erratic.
Byte 10 passes both checks, but its growth is both too fast and too erratic.
Byte 12 is zero in both cases.
Hmm.
Maybe the CCM needs to see the car moving in order to trigger a MPG query? I don't think I can make much progress until I get some data with the car in motion. I also need to log to a file through Python so I can avoid the overflow issue.
If you have a way to get the car up in the air, you could do testing without physically going anywhere. The VSS is on the transmission, not the individual wheels (the wheel sensors are used for the ABS/ASR, not the CCM and ECM).
That's a good idea about elevating the rear wheels. I'll give that a shot. I wanted to do that anyway to diagnose a clutch issue.
A little off topic, but does a Mode 1 ABS request include wheel speed? I'm thinking of ways to implement traction control with my standalone.
Yes, the ABS Mode 1 Message 0 includes the wheel speeds for each individual wheel. For the '92 ABS/ASR, refer to A175.DS. For 1990, A134.DS.
Thanks, I'll check the definition out. That's a big help.
I got some data with the rear wheels off the ground, but I'm having trouble making sense of it. There are no new messages that I did not previously describe, so the data I already had must have contained all of the elements of the MPG calculation. There were two $50 messages (out of a thousand in that log), but each one had a checksum error. I think those must have just been partial transmissions, because the only other checksum error I got was a message immediately before one of the $50 messages.
In the thousands of messages I captured, every single $40 was identical ($40 55 6B), so that's not it. The $F0 messages were likewise identical.
We've also previously ruled out $10. I looked through the logs, and all the $10 messages are the format already seen. As an aside, I think I have something mixed up for byte three. In my log, I triggered the dash to metric, then back to English, then turned on the AC. Byte three changed from 0x08 to 0x09, back to 0x08, then to 0x0C. I'll table that for future investigation.
This brings us back to $41. I don't have the energy to reason through this tonight, but here's the raw data. While I didn't timestamp the log to mark the events listed, I figured them out from data in the serial (i.e. RPM goes from 0 to nonzero; VSS goes from zero to nonzero).
Right before and after starting the engine:
$41 61 00 E5 00 3A 39 01 01 00 18 B4 00 01 37
$41 61 35 3B 00 3A 39 01 0A 01 C8 B4 00 01 F2
I'm tentatively thinking byte 8 could be the running total fuel. It's also possible that byte 2 correlates with injector BPW. Here's a plot from a datalog:
Byte 2 shows the same trend of an initial spike, then a dip, then gradual recovery to an in-between value.
Edit: The only other thing that makes sense for byte 2 is RPM. However, byte 2 leveled off at about 40. Assuming that was at 800rpm, the maximum value of 255 (0xFF) would be only 5100rpm. On the other hand, byte two being 40 at ~1.5ms BPW would mean 255 would be nearly 10ms. The largest BPW I can find in one of my logs is 8.9ms, which is perfect.
I think I can verify this by taking a log where I stab the throttle at idle. BPW should suddenly jump and then fall back down with RPM lagging behind.
It's probably not necessary, but I think I'll update my script to plot this data real-time so I'm not running back and forth as much.
Edit: I've noticed some strong similarities between some bytes in $10 and $41:
- $10 byte 3 (coolant temp) and $41 byte 5
- $10 byte 4 (RPM) and $41 byte 2
- $10 byte 5 (speed) and $41 byte 12
One way to still use the C68 to display engine parameters is to implement another interface. Right now you are working on serial communications but if your aftermarket ECU has an OBD2 interface, you could use that to retrieve the parameters with the Arduino and put the data on the serial line.
@Mike in Boston , I was thinking - I believe you told me that your rear defrost will not work because the CCM needs to see that the car is moving. However, the CCM is directly wired to the VSS, so serial communications should not affect that. Am I misremembering your issue?
1. Use a logic analyzer. This is a separate physical tool, which should be connected to a different computer from the one you're using to talk to the car. You jab a pin into the serial data wire on your car, then it just listens to every single thing on that wire. This is how I'm reverse-engineering the ABS/ASR signals from the Tech 2.
2. Use a piece of software called a Serial Port Monitor. While experimenting, I used the free trial of HHD Software's "Serial Monitor." It did exactly as described; I was able to easily log all communication between my laptop and the car while reading from and flashing the PCM on my car. It was thanks to this software that I was able to get datalogs comparing how EEHack, Flashhack, and DataCat flash routines work. Instead of paying for the full version, I bought a logic analyzer.
As for the objective, once you have the hex data, you can start comparing it to known ALDL information and see if you can identify what exactly is being said by what device and when and what it contains. You would then, potentially, be able to replicate those signals in order to make the CCM and such happy even if you swap ECMs.
You don't need to do that to tune one of these cars. That's easy peasy, no reverse-engineering required. But getting an aftermarket ECM to play nice with all the other computers in the car? Good luck; to my knowledge only Torqhead has done that.
I'm not sure how to address your final question before you asked if you're way off. The question doesn't make sense. Could you try rephrasing it?
