1996 Emergency Brake question
My emergency brake doesn't hold the car. It does moves the lever on the caliper but not enough to hold the car. It says it is self adjusting but it only moves the cable a little bit. Is the cable just to stretched out? How do I know if it is the cable from the handle or the cable under the car that is stretched? Or do I replace it all for good measure?
Also, when I release the cable the little arm on the caliper on the passenger side doesn't release. I have to tap it or push it to get it to move back to the resting position. The return spring is there and it's very strong. What would cause this to hang up?
You need to check the mechanism all the way from inside the car out to the calipers/assemblies and see if the adjustment mechanism is not working/needs lubed, etc.
Cables do stretch depending on how often they are used.
AND not sure what to do with the sticking caliper lever.
So when I got my hands dirty on this, I was baffled what the heck the problem was. The cable routing is not complicated once you identify what goes where. There’s an equalizer cable that splits the operation into two cables from the main cable at the operating lever inside the car. There’s also a thin flat spring under the car that takes up slack. That’s it. Very simple and clean design in terms of cable connections and design
If you have your cables disconnected at the caliper levers, you can test them for smooth operation very easily. You should be able to push/pull them by hand quite easily. These cables are also very beefy and therefore I’d be surprised if they stretched.
My issue turned out to be sticky operation of the main lever inside the car. This lever assembly is an impressive piece of mechanical operation in how it ratchets and self adjusts. It’s quite ingenious how it pulls the cable to a stop and then can freely move back into resting position. It’s hard to describe how it actually works here and I can’t recall the actual assembly of parts. Doesn’t necessarily matter because all I did was clean it with brake parts cleaner to free the sticky dried grease and restore the operation of all the moving pieces with some new grease. I like Wurth HHS because it sprays bubbly liquid and dries to a sticky grease. The grease has extreme pressure (EP) properties, which is good for long term use. So it’ll penetrate
Therefore I would suggest you remove the door threshold/sill covering and then remove the lever assembly from the car so you can get an up close look at it and clean it. You may be surprised how gummed-up it is and that’s why you’re not getting enough “throw” on the cable operation. My situation was sort of reversed from yours, such that I couldn’t get the brakes to release on account of the adjuster sticking and making it seem like the main cable was too short. Obviously that cable could stretch but it certainly won’t shrink!. So sought the problem in the hand lever assembly after I determined the cables and calipers were fine
I can’t help with the caliper behavior as I haven’t worked on those yet. I’ve only had the car since April 2020 and it’s my first Vette. So I’m still learning a bunch about it
Like is always said here, the factory service manual is a super good resource. I can snap some pictures of the pages later if that helps. I recall the section on the parking brake lever assembly was very short. I have glanced at the brake pages (I plan to re-seal all of them with new piston dust boots and pressure seals) and I recall looking at the rear brake caliper images and thinking, ugh, I’ll look at that in detail when I have more time. Basically, that little rear caliper has a lot of pieces to it. The caliper exploded diagram made me wish for a moment I had the ‘87-older style drum brake inside the rotor hub, which works good on my old Porsche 911s and other cars I’ve had. Well, sort of. The drum style has many more parts and is prone to failure due to age/rust. Especially here in the Midwest.
